Question about Vizio VP322 32 in. Plasma TV
Power issue When attempting to power up the tv, by remote or manually, the tv does not remain on. It takes repeated powering up to get the tv to remain on; uppers of two minutes of repeated attempts.
  • Vizio Master
  • 8,457 Answers
Must take the tv aparts.U have a soldering iron,and solders?Some basic electronics skills.Trace ur power supply board replaced all those capacitors that bulges,or puff up.Ur power will come back and work as normal again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Apr 24, 2010
    Sergeant:
    Champion:
  • 431 Answers
It is caps but just replacing ones with bulge may not fix it need a esr meter alot of 470 mic caps are bad with no bulge
Posted on May 05, 2010
Need a code for a mitsubishi tv for all for one big easy ht plus remote
Hopefully this will help. These codes are straight from the One for All Big Easy HT Plus Remote manual:
Mitsubishi: 0150, 0093, 0019, 0178
To program the remote to control your TV:
1. Turn on your TV.
2. Press the "TV" button on the remote.
3. Press and hold "Setup" until the indicator light blinks twice, then release the "Setup" button.
4. Enter the first code provided above.
5. If you have entered the code correctly, the light will again blink twice.
6. Aim the remote at the TV and press "Power." If the code is correct, the TV will turn off.
7. If the TV remains on after pressing "Power," repeat steps 2-6 for each code until you find the one that works for your TV.
Find the full manual here
If you found this solution helpful, please give it a positive rating!
Jun 15, 2011 | Televison & Video
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
I need the code for the philmore pm-rc1a so i cant watch my tv!
Try this as most remote controls work the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Televison & Video
I want to progam remote and I lost the manual
Try this as all remote controls work about the same when manual setting.
Note:
Sep 28, 2009 | One For All URC-3300 Remote Control
Have a Jumbo big remote. Lost all codes for the TV and video, need them to program jumbo big remote.
Try this as all remotes work about the same when manual setting.
Note:
I NEED CODES FOR MY SANYO TV
Note:
Sep 28, 2009 | GE JASRM24912 Remote Control
Tevion universal remote md 80383 need instruction manual
Note:
Sep 25, 2009 | Panasonic Televison & Video
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
Vizio VP322 32 in. Plasma TV Logo
417 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
