Question about HP Pavilion dv4000 Notebook
I installed a new hard drive...Unit working GREAT. Except no soun
Unit working great....Can't get sound or volume control.
    President:
  • 2,678 Answers
Install sound drivers
Posted on Apr 24, 2010
Installed new hard drive (old one crashed) no sound now
You need another sound system. If it's xp it is probably ac 97. However; go to windows update, make sure you have all of the updates. Then go to the control panel, device manager and look for a yellow question mark or a yellow exclamation mark, if there, right click and click update driver or click uninstall from the system, restart the computer and windows will look for the drivers, just follow on screen directions.
Jul 08, 2010 | Gateway GT5228 PC Desktop
Works great , but Ipod dock only will give about half volume
All Ipod docks bypass the audio processor, so your volume and equalizer presets on the ipod will not work. Use the volume knob on the home theater unit itself.
Dec 20, 2009 | Audio Players & Recorders
AC only works on settings 3 & 5
souns like a bad blower resistor.the resistor controls the different speeds.sometimes every speed except the highest will stop working.the blower resistor is almost always near the blower motor.
Sep 03, 2009 | 2004 Chevrolet TrailBlazer
KCA- 420i and an alpine 9854r Can't change the volume for Ipod
There is a small switch on the unit's housing, switch it to "Norm" position.
May 08, 2009 | Alpine CDA-9847 CD Player
Soun Drive+Task Manager related problem
This seems like an internal Mute,
go to the sound settings and select a new sound theme in controll panel and see if this helps.
if not then you may want to consider backing all your files up on a external hard drive and doing a full system restore back to factory settings
Please rate
Feb 21, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Laptop speakers won't work after installing logitech USB speakers
Okay, go to the HP website and download the speaker drivers. It will require a reboot.
Also, try checking the Control Panel Sound Settings if the volume is low from there. This is because increasing the system volume won't work if there is a mute enabled on the speakers themselves.
Also check if the item 'Use This Device (Enable)' is selected. Go to your speaker properties. It is in the dialog box that appears now. Loom at the bottom of it for a drop down menu.
The volume settings are available in the other tabs. Make sure the volume is at 100 and the mute is unchecked.
Please rate this answer. I want to get to a higher level. I am a great contributor to computers in Yahoo! Answers too.
Dec 04, 2008 | HP 2133 Notebook PC
No Sound
go to standby hold m-log button tell menu comes on display press up on volume control tell amplifier comes on display pess left on volume control tell display says amp on. the built in amp on the stereo turns of and on to provide better sound quality to the pre-amp out puts
Oct 03, 2008 | Kenwood KDC-X590 CD Player
Nad c372 Remote Control
Hello Robert,
If the standby/protection indicator on the amplifier blinks when you specifically press the volume +/- key, it obviously indicates that the unit is receiving the remote's command.
Try the following while pressing the volume key on the remote:
1.- Put your ear as close as possible to the volume control knob and listen for the sound
of a motor spinning, if you hear it, the volume control assembly needs repair. If you
hear no sound, proceed to next step.
2.- Gently rotate the volume control knob on the amplifier unit (it might be stuck and
needs a "little help").
If none of the above applies, the unit needs to be opened and troubleshooted. I've seen many instances where the volume control motor was not properly connected to the board or the assembly was put back incorrectly (specially in units that have been opened to be refurbished). I've heard NAD has a limited warranty for refurbished items. It might be wise for you to check before sending the unit for repair at your expense or trying to tackle the problem yourself. Hope this helps.
cancerags
I
Dec 26, 2007 | NAD C372 Amplifier
HP Pavilion dv4000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
