Machine suddenly stopped working says the door is open when it is shut
  • madguzzler May 11, 2010
    needs a new sensor switch on the door
    Scholar:
  • 74 Answers
Hiya .. Is there a metal hinge catch on the washer, where the door catch closes to? If there is.. its either loose, or the catch on the door itself is loose, which is normally made of plastic, tighten these up, see if this eleiminates your prob
Regards faggly
Posted on Mar 23, 2008
6ya staff
SOURCE:
My May tag Neptune washer stopped draining. I think my son jerked the door open while water was still in it. The door shuts but the lock door light doesn't come on hence the washer want start.
door switch is damaged and will need replacing should not be able to open the door in use. machine will only work when it knows the door is locked.
Jun 04, 2018 | Neptune Washing Machines
Garage door opener
Check photo eyes. Shut off power to units and try again
Aug 21, 2016 | Building Materials
2008 GMC Sierra pickup. Driving and all of a sudden it shut off then turned back on; the doors unlocked then locked again. Now it won't do anything. Checked the oil and it was empty - no oil at
Running with no oil is death for the motor ( Seized). When the alternator stopped working because the engine stopped the door lock control opened the door locks as it said you were below the required speed to have them locked
Mar 31, 2013 | 2008 GMC Sierra 1500
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Hi there. my machine suddenly stopped 2 mins
there may be something small that has stopped the pump from draining.use a shop vac and attach it to the end of the drain hose and remove the water.once this is done unplug the unit for a couple of minutes then plug it back in this should open the door.then you need to remove the drain hoses from the pump and see if there is anything stopping the impellar wheel from turning.
Sep 21, 2009 | Washing Machines
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
Front load washer isn't spinning out
The first thing to check is if the door is locking. Put the unit into spin turn unit on let it go for about a minute then shut it off, try to open the door right after you shut it off if the door opens you need a door switch if not chances are you need a motor control board. Before replacing the board call for service they are expensive if it is a guess. good luck
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
My microwave has stopped working and switched on suddenly!!
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1660 Microwave Oven
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
