Question about GE DRSR483GD Gas Dryer
My dryer Start Switch will turn on and hum but will not keep the dryer running. Could this be only the start switch and is it simple to change?
    President:
  • 949 Answers
Unfortunately it is not the start switch that causes these symptoms. It is the drive motor itself.
The motor is pretty difficult to replace on this unit but if you have a lot of time, patience and mechanical ability you can do it. The cost of a GE dryer motor is about $175.00
Posted on Apr 24, 2010
The start switch has to be continually pressed to get my dryer to work
Your motor has start and run windings, start windings for a high torque start and run windings to keep it turning, either there is a fault in the wiring or in the motor its self, depending on the dryer it may have a centrifugal switch to change windings and could be as simple as needing a clean of the contacts.
May 29, 2016 | Tricity Bendix Dryers
What causes Electric dryer to not start & run
Open the door and depress door switch have someone activate start button when humming rotate drum if it starts and continues to run replace motor
Apr 04, 2015 | Dryers
Spin dryer switch on but still hard to start otherwise if shafting is pushed clockwise it runs very slow.
Have try to turn the switch on top on the right and then hit start
Mar 10, 2015 | Dryers
DRYER HUMS WHEN CNTROL KNOB IS PRESSED & MOVES SLIGHTLY..IF HELD IN TOO LONG IT BKICKS BREAKER. MODEL#HYE3658AYW
Greetings,
This sounds like the motor is bad, or going bad...I would have someone help you try and start it....open the door and hold the door switch in and keep holding the door switch while pushing the knob to start it and at the same time....have someone try and turn the inside drum usually, counterclockwise and see if it takes off....if it does...let go of the start switch up on console(timer),
but keep holding in on the door switch to let it run for awhile...you can shut the door real fast and it should keep running... if none of this works and it still will not start and just hum...the motor is bad
Dec 08, 2010 | Maytag Dryers
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
When i turn the on switch i hear a humming as if it is going to start but it does not. my dryer brand is Frigidaire FEQ 332 E s
Depending on the hum you hear (if you hear the sound and it keeps humming) the belt that connects the motor and the drum is probably broken.
If the hum only happens when you turn the on switch, the motor has probably failed.
Aug 31, 2009 | Frigidaire GLEQ642A Electric Dryer
Whirlpool LER4634EQ
ok is the humming coming from start switch or from down near the motor? usually it inst the start switch because the switch is so very simple of a component nothing goes wrong with it. kelly
Dec 22, 2008 | Whirlpool LER4634J Electric Dryer
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Feb 14, 2008 | Dryers
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
GE DRSR483GD Gas Dryer Logo
71 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
