Question about Delphi Roady XT XM Radio Receiver
What frequency should car radio be on to access xm
What fm frequency should car radio be set to access xm
  • Delphi Expert
  • 509 Answers
Go to your radio's MENU and set a frequency, then set your car to the same frequency.
Posted on May 27, 2010
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
How do I get to radio tune
Turn XM Roady2 'on' using the POWER switch. Go to MENU and go the FM Frequency. Select your frequency of an empty channel in your area, then turn off the Roady2 using the POWER switch. Do NOT do this by turning the car on and off as it tends not to save any settings when you do that. Always use the POWER button. Also, the website 'Radio-Locator' has a utility that will help you find an EMPTY FM channel in your are for your XM radio to use! Good luck and let me know how it works out for you- okay?
Jun 12, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
I have a portable XM and want to run the antenna through my FM radio and my zip is 50595. I can not find the webiste link that lists available FM Frequencies by zip, any ideas on that?
Yes, go to "Radio-Locator.com" - they have a selection for finding unused FM frequencies in your area. Actually, your radio will sound better using an "AUX" input or a cassette tape adapter.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
Jan 22, 2009 | Car Audio & Video
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Audiovox Xpress XM Radio Home Dock Problems
home dock does not allow the fm frequency generator. it only works in the car dock
Nov 18, 2008 | Audio Players & Recorders
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Delphi Roady XT XM Radio Receiver Logo
194 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
