Question about Philips 42PF7220A 42 in. Plasma Television
42pf220a/37 Philips TV - Red Blinking LED wont turn on
HI
My TV started to act funky when I turned it on a couple of months ago. It makes a cutting in & out squeaky noise with the sound and the picture cuts on & off until it seems like it catches itself and gets warmed up. The problem has gotten worse and now the tv will cut off and a blinkging red LED will come on the front of the tv. It blinks 6 slow blinks then 3 fast blinks. If I unplug the tv for a minute and plug it back in it seems to reset it and sometimes I get it to turn back on, but it does do the cutting in & out thing. What seems to be the problem, is there a code book for the way the LED is blinking to know what is wrong, is it something I can fix myself?
  • lcusumano Apr 26, 2010
    What does the blinking code mean??????
    6 slow blinks and then 3 fast blinks
    Is there a way to get the tv to turn on with out having it serviced?
  • 10,515 Answers
Unfortunately, the only way to Reset the TV is to keep it unplugged for Few Minutes.You actually did this many times, However, it would still never solved the Problem.This is an Internal Failure which needs you to Open the TV and check Components. If you have tools like Multimeter and experience, i would be glad to assist you .
You would need Schematics as well. So, we could also get that from a Service Manual. Make sure that you need to do the Repair perfectly as a small mistake could Damage the TV.
Let me know,if needed further assistance,
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 26, 2010
    Genius:
  • 1,043 Answers
This particular blinking code usually signifies a pair of capacitors, 3300 uf 10 V, that are located on the power supply board. A visual inspection usually shows that the tops of the capacitors are bulging. If the caps are the problem I would strongly advise that they be replaced with a better grade of capacitors.Once this is done you will also want to ensure that you have the latest firmware upgrade from the Phillips website. If you have the experience and the tools to do the repair yourself you will want to set aside a bit of extra time as the power board is well buried inside. If you are going to have to pay a repair shop to resolve the issue you should have them give you an estimate first. Unfortunately this can be an expensive repair because of the difficulties in getting to the board. With the price of flat panels dropping over the last couple of years the cost of replacing the TV may almost equal the cost of the repair.
Good luck and thank you for allowing us to help identify your issue.
  • bvanjoff Apr 26, 2010
    There will not be anyway around getting the TV to work without getting it serviced. It is quite possible that if you keep trying to use the TV with defective components inside the result will be more components becoming defective and the cost of repairing the unit will keep rising.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It is due to the high voltage shutdown which might be exceeded 33k and the unit shuts it self down to protect other parts being damaged. Also please check power supply regulation and horizontal circuits. If these are fine then it means Small Signal Board has gone bad. You’ll need to replace Small Signal Board. It will cost around $300+. As this board requires special set up, you’ll need to contact a qualified TV repair tech. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 25, 2010
Philips 42PFL7403D/F7 LCD TV. red light blinking where the on/off light is. TV will not turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 23, 2015 | Philips Televison & Video
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Tv. does not turn on sometimes? philips 63pf9631d/37
i had same problem. i took apart my tv and found there was debris stuck between the plastic push power button and the little sensor thing it touches. having it on it would randomly turn off. i adjusted it and it was fine. but now it just pops a fuse lol. hope it helps.
Feb 15, 2009 | Philips Televison & Video
Problem
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking LED and auto turn off
The repair kit comes with instructions for a skilled tech.......
Part # 483531057673 Horiz driver.......All L04.1U Chassis.....T.
Dec 22, 2007 | Philips 32PT6441/37 32" TV
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
431 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
