Question about Garden
Chain lubrication not working - Garden
    President:
  • 2,220 Answers
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). Post back with a make and model and I can be much more helpful.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
  • 2,841 Answers
First make sure the oil tank if full. If it is, then check the pump and orifice. There is a small pump in the chain oil tank that is driven by the same shaft that drives the chain. First you could check that the hole at the base of the chain is clean as it could be plugged and not allowing the oil to come out and if it looks good you will have to work your way back to the pump cleaning as you go but this takes some disassembling of the chain saw.
Lubricate has stopped flowing to lubricate the chain when in use. What should I do?
didnt specify make model ---generic answer--check level in tank ---if good remove cover, chain,and chain bar and look for a small foam sponge type material on inside frame along where chail and bar are thats what allows the oil to lube chain if covered in debris or clogged clean and or replace the following link showes the ioler on different models
Chainsaw Oiler Not Working Yahoo Video Search Results
Jul 12, 2016 | Garden
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
How to stop flow of oil on to chain?
Interesting.
Chain lubrication
is critical to the life of the bar and chain.
I'd be suspicious that you may not be using heavy viscosity chain lubrication oil.
Light weight oil will flow much faster.
Dec 03, 2015 | Garden
Noisy automatic door opener, what can be used to lubricate it
Absolutely! When I had a repairman replace a broken spring, he used WD40 on hinges, rollers and the chain. Worked great. That's what I do now
Sep 17, 2014 | Wd40 Open Stock Lubricants 10110...
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Jul 14, 2014 | Remington 10" Model Rm-1015p Electric Pole...
What Oil is used for the bar & chain lubrication
Hi khipiercy...
You will use "Bar and Chain Oil" for your chain and bar lubricant...it is specially formulated to be used on chains and bars of chainsaws...
You can buy it at any Loews,HomeDepot, Ace Hardware, etc.
Please take time to rate me
Sep 22, 2011 | McCulloch Garden
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
I have a 460 rancher brand new and it cuts crooked it cuts to the left. i have tried several chains. it has a 20" bar. any ideas?
The chain may have the procedure but the driver plate is worn out - what happens when you are not attached to the chain lubrication oil lubrication channels or if the chain is about or when the pump is not working.
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
How often does the chain need lubricating
Touch your chain, feel it, does it feel super hot, does it feel sandy, does it make alot of noise, is it loose?
Riding conditions is the main factor for your chain.
Do you travel down alot of dirt roads? the worse the conditions the more frequent lubrication is required.
If your chain gets alot of dirt on it then you'll need to wash that off and then lubricate it.
A well maintained chain will also save on your sprokets.
I check mine once a week, sometimes its good and sometimes its dirty and needs washed and lubricated.
I use chain lube that doesn't fly off and get all over my bike. In a pinch any lube will due.
Nov 29, 2010 | 2008 BMW G 650 Xcountry
Lubricate the chain
Every 600 miles or 1000 km either spray wax chain lubricant or pour some gear oil on it. ,
Nov 10, 2008 | 2007 AJP PR4 125 Enduro
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
