Question about Whirlpool LER4634J Electric Dryer
Dryer spins but no heat - Whirlpool LER4634J Electric Dryer
    President:
  • 949 Answers
You have one of three problems going on here. I will list them in order of most common to least common.
- Not enough power. Your dryer uses 240 volts to heat and only 120 volts to run the drum. Check your circuit breaker to make sure it did not partially trip by turning it off completely and then back on
- Heating element has failed. The element can be checked with an ohm meter and should read under 100 ohms. It is not too hard to replace, with the power off take the back panel off the dryer, the element is in the right lower corner looking at the back, held in by 2 screws.
- Thermal cut off, just above the element on the heater box is a small component with 2 wires going to it. this fuse is activated by over heating due to poor air flow, if your venting is kinked or full of lint this part will fail, it can be checked with an ohm meter also
Posted on Apr 24, 2010
Would a faulty switch interlock stop a dryer from heating?
no. It would stop it from spinning. Now if the dryer isn't spinning then obviously it wouldn't be heating, but if its spinning with no heat the interlock switch is not your problem.
Nov 15, 2012 | GE Dishwasher & Dryer Interlock Switch -...
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer spins but won't heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 19, 2010 | LG DLE7177 Dryer
Will spin but no heat
heatman101
May 13, 2010 | Kenmore 400 6942 Dryer
Dryer will not heat. Just spins without igniting.
heatman101
May 11, 2010 | Kenmore 63942 Dryer
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer spins does not heat up
I CAN GIVE YOU THE ANSWER TO YOUR TROUBLES. THE HEATING ELEMENT IN YOUR DRYER IS GONE. CALL A REPAIRMAN AND SEE HOW MUCH IT WILL COST TO GET YA A NEW HEATING ELEMENT INSTALLED.
RODNEY
May 16, 2009 | Kenmore 64812 Electric Dryer
Dryer spin, no heat
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Kenmore 63932 Electric Dryer
Dryer no heat coming out
No heat coming out of my dryer it spins and there is good source of power...
Jul 21, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
115 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
