Question about HP Photosmart 3210 Printer
I replaced 2 ink cartridges because I thougfht they were out of ink. That's not the problem. The 2 colors do not print that color at all. The printer is a HP Photosmart 3210
  • 4,041 Answers
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
