Question about Refrigerators
My model is whirlpool FF45B of 2007 problem is cercuit for
My model is whirlpool FF45B of 2007,frostfree, problem is cercuit for defrosting is not working,ultimately cooling stops
    Sergeant:
  • 239 Answers
Need to pull panel in freezer and check defrost heater and bi metal for continuity, if goth are good then replace defrost timer
Posted on Apr 25, 2010
Kenmore model 970-180020 Water is dripping from the ceiling inside the freezer, I also have frost inside the frostfree freezer. Any help would be great.
Frost inside freezer can be caused by a bad gasket or a defrost mechanism that is not working. Could be the defrost timer, heater element, defrost thermostat.
Sep 14, 2017 | Kenmore Refrigerators
We have a 21" frostfree
What you have is a defrost problem. The defrost system has 3 parts: The control, the heater, and the heater thermostat. The heater thermostat is called a termination thermostat or "terminator". The defrost mode lasts for 21 minutes in most machines. The job of the terminator is to kill the power to the defrost heater when the temp gets above 50f to melt the frost on the coils. So what can go wrong?
The heater like anything else will go out like a light bulb does; the terminator it will swell up and fail with age as well. OR the control will malfunction. Older ice boxes use a mechanical timer while the new fangled ones use artificial intel to determine when to defrost. Having frost on the backsides of the freezer is a sure sign of ice buildup in the evaporation department.
themobilian_693.jpgthemobilian_694.jpgthemobilian_695.jpgthemobilian_696.jpgthemobilian_697.jpg
I have More Here
Jan 05, 2011 | Kenmore Refrigerators
I have a hotpoint frostfree freezer that is over
Since this is a frost free refrigerator/freezer, you shouldn't need to defrost it, and the frost should not be building as you describe.
If your OK with diagnostic troubleshooting techniques, and have a volt-ohm meter and know how to use it, we can figure out whats wrong with your unit.
Dec 16, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ice pooling in bottom of frostfree freezer
Sounds like the drain tube(s) which carry the defrost water from the freezer and refrigerator to a catch pan at the bottom of the refrigerator are stopped up.
I have seen these drainage tubes stopped up with debris which prevented the water from draining out. This defrost water can be turned into ice which blocks the defrost drainage even more so.
Oct 09, 2009 | Refrigerators
Frigidaire/electrolux frostfree stand up freezer occasionally seems to completely stop working. Even semi defrosts and leaves some water on floor. after a while it starts up again.Is there a problem here?...
I've had the same problem with my Frigidaire/electrolux frostfree stand up freezer. It's a major downer to go into your freezer to find all of your frozen foods (much of it expensive meat) - defrosted, some or all of it ..ruined. I sometimes wonder how many times it may have stopped working without us knowing, (since we sometimes go days without needing to open it) and just how creepy some of the meat that I am serving my family might be.
On top of destroyed groceries, the cows and chickens lives lost in vain - (aka wasted meat - I'm sensitive to that as the vegetarian in the family), it gets extremely hot on the outside when this occurs. It gets so hot, that we're actually worrying about a fire. It's almost like it is periodically overheating and going into an auto-shut down mode.
Needless to say, we are not "digging" our Frigidaire/electrolux frostfree stand up freezer.....
We are considering ditching it and buying some other model - refurbished. This just stinks... is disappointing... we paid a ton.. and now it's headed for a landfill.... (really?) JUST LOUSY!
Would LOVE a solution.... would love to know of others with this problem...
Sep 16, 2009 | Freezers
I have a candy frostfree fridge freezer GL90AA; it never switches off,i.e. I can hear it run all the time.
If it is not reaching the cut off temp because
the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everythinghttp://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Candy CPCA240FFK Bottom Freezer...
Frostfree fridgefreezer defrosting
Your defrost system is going out. You have three parts: heater, timer and t-stat. Start with the heater first. Call us for parts! Hope this helps! Ella
Aug 18, 2009 | Candy CPCA240FFK Bottom Freezer...
Freezer working refrigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 03, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool arg667 frostfree fridge/ freezer. fridge section not cooling, freezer basically ok. could it be a circulating fan? Help!
yes it could be the fan,try completely defrosting it manually then restart it ,if you can then feel airflow it will be a fault in the defrost system,either timer,heater etc,if after defrosting manually you cannot feel airflow it will be the fan or fanblade faulty
Aug 10, 2008 | Refrigerators
Whirlpool Frig
Is that everything in your freezer or just in the fridge. Is this a frostfree model. Often if defrost fails in a frost free model then it is unable to duct cold air to the refrigerator side of things. To fix- turn it off for a day or two.
Mar 16, 2008 | Refrigerators
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
