Question about Nokia 6630 Handheld
6630 battery problem
I have a problem with may 6630 batery, two days ago it just got empty in 8 hours after charging and now this happens every time I charge it. I tryed a new battery but I had the same problem. what could be the prolem?
  • Anonymous May 01, 2008
    my battery drained quickly after a long time of charging.. can somebody help me plzz...
  • 169 Answers
System might be corrupted.
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory.
Posted on Jun 21, 2008
My phone is not in use these days but it gets discharged only after few hours needs solution
you need to change your battery, normally we do mistake when we dont need of mobile we leave battery inside of mobile which is not correct method that kills battery. this is what happen to you. so now solution is change the batery and new one charge switched off mobile up to 8 hours.
Jun 19, 2012 | Nokia E63 Cell Phone
How to charge new battery in my laptop
as i do not know what laptop we are talking about here i asume its not a notebook
if it is the time is slightly lower (6-8 hours)
a normal lap top 10 - 12 hours.
some super batery laptops come with an own (long) guide how to keep the batery alive.
to keep the batery alive a long period of time charge it from 50% not when its at critical.
If u can take out the batery when you are using cable and its fully charged it also has a longer life time. or just take out the cable when its at 100% and recharge it when it gets to 50%
dont have your computer in the lap it can over heat the computer/batery and the lifte time gets even lower.
Aug 24, 2011 | Dell Inspiron B120 Notebook
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
Input voltage : 100-240 V, 50/60 Hz
Power consumption : max. 9 W
Motor voltage : 2.4 V
Battery : 2x NiMH AA
Battery capacity : approx. 1100 mAh
Charging indicator : 1x duoLED green / red
: charge / battery low
Charging time : approx. 8 hours
Charging current : 200/25 mA time dependent
May 21, 2009 | Philips Philishave Cool Skin HQ6740...
Batery gone quickly in one call, eventually cut off
is your battery easily fully charge when you charge it? and easily went down after?? if yes, that migth be battery failure..
if not, there can be some shortage in your phone.
Mar 17, 2009 | Lands Phones
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Nov 15, 2008 | Computers & Internet
6630 "Not Charging"
my frind use corect batery that is Nokia BL-5c 3.7V made in hungary
Aug 17, 2008 | Nokia 6630 Cellular Phone
Nokia 6630 Handheld Logo
184 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
