Question about Epson Stylus NX400 InkJet Printer
How do I load the ink cartridge in the printer?
The ink cartridge will not stop in the position that would allow me to add the new ink.
  • 779 Answers
Posted on Apr 24, 2010
Print cartridge would not move to loading position to allow installation of new cartridge
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 17, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How do i change my ink cartridges in my kexmark x3650
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-head will slide to a position from where you can "unlock" and then remove an ink-cartridge.
Apr 10, 2011 | Lexmark X3650 Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
How to remove ink from printer
Ink Cartridge Maintenance
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How to instal a new printer ink cartridge
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Cant load the printer cartridges for the pixma mp190
If you are trying to figure out how to load your ink cartridge in you Canon Pixma follow these instructions.
Make sure you printer is powered on. Open the top cover including the key display.
  • Step 2 Allow the ink return to move to left and stop. Remove the old cartridge which should have a 40 Black or 40 color on it by pushing down and popping it out of the holder.
  • Step 3 Now open your new ink cartridge and tear off the protective stip from the ink cartridge.
  • Step 4 Place the new ink cartridge in at a downward angle and then push into a straight position by pushing the bottom into place.
  • Step 5 Close the top an allow for the printer to adjust into place. Do a test print to make sure the printer is working correctly.
  • Step 6 If you experience an error message refer to your canon guide book for troubleshooting tips. Be sure your new ink cartridge in placed in correctly. Should be next to the other ink cartridge in same alignment.
  • Mar 22, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    Epson Stylus NX400 InkJet Printer Logo
    125 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
