Question about Samsung SCX-4216F All-In-One Laser Printer
How to fax system install - Samsung SCX-4216F All-In-One Laser Printer
  • 4 Answers
CONNECT TEL TO TEL SOCKET IN THE MACHINE & START USING THE SAME
Posted on Apr 24, 2010
MY DELL 948 WILL NOT SEND A FAX
there is a generic Fax program in windows XP. If your using the vista home basic or home edition, it does not have these function unless you install an actual fax program. If not you can install it by
for XP -go to the start -control panel -go to the windows add remove programs -add remove windows components and choose the Fax services
-Vista -go to start -control panel -programs and features -add remove windows components and choose the Fax services
hope this helps
Jun 23, 2011 | Computers & Internet
Tip
Windows XP fax
If you need your<b> PC</b> to be able to fax, you must install the <b>Windows XP fax</b>. Add / <b>Remove Programs</b>, click Add / Remove <b>Windows Components</b>. In the <b>Windows Components Wizard</b>, select the check box next to <b>Fax Services</b> and make sure you have the installation CD handy.
on Feb 24, 2011 | Computers & Internet
Tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 | Computers & Internet
I cannot send faxes or make copies with my Brother intellifax 1270e. When the paper gets to the read point sensor it stops and says "press stop button" . The machine will receive fine and print...
Cleaning the Scanner
Before cleaning, unplug the power cord for safety. Clean the white roller and the glass
strip under the roller with isopropyl alcohol on a lint-free cloth. You'll need to lift the
two release levers to release the white roller; be sure to lock them in place when you're
through.
During cleaning, I recommend you unplug the power cord for safety.
Brother fax-back system (USA Only)
Brother Customer Service has installed an easy-to-use fax-back system, so you can get
instant answers to common technical questions and product information for all Brother
products. This system is available 24 hours a day, 7 days a week. You can use the
system to send faxes to any fax machine, not just the one from which you are calling.
If you can't resolve difficulty with your fax machine using this manual, call our
fax-back system, and follow the voice prompts to receive faxed instructions about
using the system, and an index of fax-back subjects.
The Brother fax-back system number has been preprogrammed on One Touch key
Dec 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Trying to fax from windows XP Professional. Have
Have you downloaded and installed the device-driver software from HP's web-site (http://support.hp.com) for this specific all-in-one device? It may include software to cause "printing" from Windows to be routed to the FAX-interface on the all-in-one.
Oct 29, 2009 | Microsoft Windows XP Professional
Problem with fax, when fax is turned no it read scanner driver not working. can you help.whenever a fax is sent we don't come through you can hear it dialing fromthe other end that all tried to install new...
scanner drivers have not been properly installed .it requires fresh installation of software after removink previous install of software. tell me ur operating system,i will give you steps to uninstall previous software and install new software.as far as fax is concerned,first we have to install drivers,then ur fax issue will be solved
Aug 17, 2009 | Office Equipment & Supplies
FAX PROG. TRYING TO DOWNLOAD EVERY TIME I LOG ON AND I DO NOT HAVE A FAX.
If you have a modem installed in your computer Windows will try to set up the fax functionality. If you have your Windows installation CD, insert it and install the fax software. That is the best answer I can give you based on the limited information you gave.
Aug 13, 2009 | Microsoft Windows XP Professional SP2
How do i turn on the fax feature? C250 does not recognize the fax board installed.
hi, enter tech/rep. utility/counter/stop 0 0 stop 0 1. touch system 2 , touch option board status, touch set of fax main, touch end once, touch system 1, touch marketing area, touch fax target, select country code, touch end twice, touch fax, touch initialization, touch fax function parameter and communication journal data , touch yes twice, touch end, touch exit, turn main power off for 10 seconds.......done...good luck
si
Jul 02, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Cannot Install or Uninstall printer
Hi u need not install fax software for this machine..its a standalone fax machine..the fax software provided for fax is for computer faxing..
first find which operating system u have on ur computer..if its vista..try downloading drivers and then installing
Feb 11, 2009 | Lexmark X5495 All-in-One &USB...
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
Samsung SCX-4216F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
