Question about Kitchen Ranges
My water softner and filter giving me black water does anyone know why is is a whole house system. thank you
The grey colored filtered water that you are experiencing is a result of carbon dust being released from your tap water filter cartridge. Black colored water is made up of Hydrogen sulfide, also known as sulfur. To fix this you will need to use an aerator that sprays the water into a holding tank and clean the holding tank (twice a year) and spray heads out with bleach. Click on the link below to read more:
http://www.filtersfast.com/forums/whole-house-water-filter-systems/1208-new-iron-filter-now-i-have-black-sediment.html
Posted on Apr 24, 2010
Kinetico reverse osmosis water flowing very slow
I am guessing you have checked to make sure the water flow into the osmosis system to make sure it is at proper pressure? If so is this a whole house system or just for the kitchen? If it is a whole house do you have the same problems in other parts of the house?
Jan 21, 2013 | Refrigerators
What are the methods for water purification?
Purification methods can be divided up into settling of suspended matter, physical or chemical treatment of colloids and biological treatment.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
The water pressure in the entire house is very poor. If more than one water tap is open the water trickles out. The house has a Culligan Water Softner system. Is there a filter or some other home...
First make sure all the filters on all faucets (kitchen, bathrooms and even the dish washer and washer) are clean and not clogged, sometimes on areas with hard water you will experience sand and minerals to accumulate and clogged all filters. If all filter are clean with no minerals, then your problem could be the culligan filter, ask your sales rep to perform an inspection for minerals on all ending lines.
Hope this clear up your water lines. It happened to me.
Aug 09, 2011 | Culligan 34" Whole House Water Filter...
My Culligan water softner is leaking from the coonection where the tank and the control head meet how can i fix this problem?
It depends on how old it is. Older Culligan systems(pre 1999) have separate inlet and outlet on tank and have washers that fit inside the "FEET" that slide onto tank. Newer style systems have center opening tanks with o-rings that seat on tank. You need to see what model it is. Bypass the system, run through a manual regeneration to relieve pressure, then you can change the washer or o-ring. They are only available at Culligan.
RJ
Mar 24, 2011 | Culligan 34" Whole House Water Filter...
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
Silver water softner sounds like water running all the time
It is running to drain. The sealpack (main piston & sealpack are one unit) is bad and needs to be replaced. If you are handy you can do this yourself. There is a retrofit kit to help repair these issues. It is only available at Culligan. It is about $10.
RJ
May 13, 2010 | Culligan 34" Whole House Water Filter...
I have a culligan water conditioner, are there filters inside unit? Im by passing the unit now. When water goes through system, water pressure drops.
yep got to replace the filters if any in line or your softners need to be relined if you cant see your filters in a plastic clear houseing then your sadly gonna have to call culligan water to come reline your tanks
Mar 28, 2009 | Plumbing
Hi, I have a whole-house heavy duty water filtration unit from GE. When I go to replace the filter, it and the entire inside of the filter system is coated with a purplish slimy substance that stinks. I...
do you use liquid soap or fabric softner,if so change to small amount of powder.try filling the machine with really hot water and let it soak for an hour or so.hope this helps.
Mar 24, 2008 | Washing Machines
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
