Question about HP Color LaserJet 8550dn Printer
Removing HP Laserjet 8550 from its plinth
I'd like to know how to remove my HP Laserjet 8550 from its old plinth to put it onto my new Tray 4. It feels bolted on but I can't see how to release it :(
  • 141 Answers
SOURCE: to install a 500 sheet paper tray for hp laserjet 5 printer
make sure you reboot the printer after doing so or the printer will not recognize the new tray 3 assembly.
Posted on Oct 11, 2008
POCBM
  • 121 Answers
SOURCE: how to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Posted on Mar 04, 2009
SOURCE: HP 8550 not printing
Disconnect your network cable and printer's hard drive and then power on. Its possible there is a stuck job somewhere.
If that doesn't work, believe or not it could be the fuser.
Posted on Jun 06, 2009
  • 9 Answers
SOURCE: hp laserjet 4050n con't print from automatic paper
1.Make sure the guides on the back of the tray is set properly as well and the pages have not slid back further then they should. Say if you are using letter. Make sure the tray guide are exactly on letter.
2.Often the paper pick up roller gets paper dust on it, and it gets slippery.
Only clean it with a relatively lint free, cotton cloth, dampened with plain water. Any other cleaners can dry out the rubber, and shorten the life on the roller.
3. If you notice the blue pickup roller on the bottom of the tray is getting worn it needs to be replaced. Some times you can get a few thousand more pages out of it by swapping it with the other one that is up in the printer. If find it wears more slowly.
You can remove them by pressing on the release tab sticking out the front of the roller. Take out the tray and you will see another one up in the top where the tray came out.
Posted on Dec 09, 2009
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
HP Laserjet 4350n, is always wanting to print from tray 1
Typical of this machine. You have worn out feed rollers in tray 2. There are three of them, two in the top of the machine after removing the tray and one in the tray itself
May 21, 2013 | HP LaserJet 4350 Printer
Blotchy printing output for HP 8550
This is often caused by the TRANSFER DRUM having deteriorated and become 'bumpy, or 'dimpled' - take you pick depending on how YOURS looks. This causes incomplete contact with the Photo-conductor drum, and as a result doesn't lift all the image off it.
The only solution is to fit a replacement TRANSFER KIT.
I have also seen NEW 'old stock' transfer drums, straight out of the box like this, so its obviously an 'aging problem' with that component.
Also seen it in a very low count printer that was in storage, unused for over 3 years.
Dec 11, 2012 | HP Color LaserJet 8550 Printer
I have an envelope feeder that came with my old LaserJet 4 many years ago. I replaced the LJ 4 with an LJ 4-Plus and tried to use the envelope feeder on it. I get an immediate error message "EE...
My suspiction is there is a tab on the tray that triggers a switch telling the printer what type of tray has been inserted. Your old tray is likely different from the Plus 4 tray and the printer knows it.
Jun 04, 2010 | HP LaserJet 4 plus Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Jun 02, 2009 | HP Color LaserJet 8550 Printer
How to clean a density sensor unit on a hp color laserjet 8550
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
HP Color LaserJet 8550dn Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
