Question about Coffee Makers & Espresso Machines
Faema espresso machine - C84/1 - users manual
Would like a copy of users manual for the above model of faema machine. Just bought a second hand one from trade me New Zealand. Would be very appreciated if someone can email it to this email address niesanm@yahoo.com
SOURCE: User Manual
Please email me tomorrow at dspringer5114@hotmail.com. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
Posted on Jun 01, 2008
EsWorld
  • 1618 Answers
SOURCE: Faema S-87 Spouts copious amounts of water from the top
There could be one of 2 things happening :
1. Problem with auto level.
2. Most likely the inlet valve has a small leak.
Posted on Feb 26, 2009
EsWorld
  • 1618 Answers
SOURCE: espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Posted on Apr 28, 2009
EsWorld
  • 1618 Answers
SOURCE: User Manual for Faema D92/A, doesn't dispense coffee, only water
This will take some time so bear with me.
The problem with the machine is most likely the solenoid valve(black or blue electrical box connected on the side of the group), for easier access remove the front panel there are about 5 screws holding it in place, 2 on the bottom and 3 on the top under-side. Disconnect or turn off the water supply. Then using a 14mm open end wrench remove the nut and the discharge pipe. Do Not remove the 4 small allen wrench screws on the brass piece connected to the machine. Now remove the electrical box over the silver pipe, and using a cressent remove the silver pipe from the brass rectangle square. Slowly open the water supply, if water shoots out then the head is clear, we will move on if not, use a pin and clean the middle hole. Check the silver pipe also there is a small plunger in there press it in if it moves freely then we are good, if not you can try soaking it in puro caff until it clears or just get a new solenoid coil. Remove the shower screen and screw in the group head, you can soak those also.
If you still cannot get water, then we will have to go deeper into the machine.
Posted on Jun 03, 2009
EsWorld
  • 1618 Answers
SOURCE: we have an older faema due machine. Currently the
The tip of the steamwand is clogged or the fitting where it connects to the boiler is blocked with carbon.
Posted on Jun 20, 2009
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Feb 09, 2015 | Faema Smart A2 Automatic Espresso Machine...
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
I have a Faema Due espresso machine and I need to know about the correct use of the red cup symbols over the heads. Can you help please.
Faema Due depending on the model semi or auto has either 6 buttons for auto and any where from 1 to 2 for semi. There are 2 short level cups single and double and 2 long level cups. They are for ristretto or restricted and lungo or long, but if you only use 2 ounce or 3 ounce shots depending on your preference. I usually set all buttons to shop preference because in the US most shops either do 2oz or 3oz espresso shots. The cup with the dots above it is continuous run and ofcourse the stop is... On the semi you have one cup and stop or a push button.
Mar 23, 2013 | Faema Coffee Makers & Espresso Machines
Need a users manual in english for the faema due espresso machine
Try Googling (faema)(FA60081)(manual) without parens. You may have to refine your search to get an English version.
Oct 10, 2011 | Faema FA60081
I have a faema due automatic single group. Works fine except I cannot program shots. I hold down the "stop" button as per the manual, but there is no "beep" initiating the programming mode. What is wrong?
Hold down button for 8 to 10 seconds. If that is not working then you might have the older model in which you have to hold down the stop plus the button that you are programming until you get the desired volume then release button and stop button.
Jun 26, 2010 | Faema FA60081
Jun 01, 2009 | Faema FA60081
I would like to know a place where i could get the technical and part manuel of the following machine: ''FAEMA E91 A Diplomat'' And please if you can get it in french version it would be appriate thanks...
FAEMA COMPANY LTD. M6G 1Z6 Ontario and Western Canada ADDRESS _t.gif 672 Dupont Street, Suite 201, Toronto TELEPHONE _t.gif 001 416 535 1555 FAX _t.gif 001 416 535 3843 EMAIL _t.gif espresso@faema.net _t.gif iko_piu.gif _t.gif FAEMA DISTRIBUTEUR, INC. QC H2R 2W5 Montreal, Quebec ADDRESS _t.gif 14 Jean-Talon West TELEPHONE _t.gif 001 514 276 2671 FAX _t.gif 001 514 276 5991 EMAIL _t.gif sales@faemacanada.com
Mar 16, 2009 | Faema FA60081
User Manual
dgsrgr8
May 31, 2008 | Faema Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
317 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
