Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
My usb external hard drive wont work when i plug it in
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
I bought a brand new fantom drive externl hard drive used it once and now it wont show up when i plug it into a usb port
Try to plug the external hard drive to a different port. if its not working try to use other usb device like ipod, or thumb drive and if the other usb device works it means the problem is the external hard drive it self. If the problem still the same the problem is the usb ports probably the motherbaord
Sep 03, 2011 | Fantom Computers & Internet
My computer wont show my hard drive when its plugged in
have you tried connecting the hardrive to some other computer. Is it getting detected on it?
May 30, 2011 | Galaxy Microsystems Galaxy METAL GEAR...
I plug in my hard drive to the USB port, but the computer/USB port wont detect it. This happens on multiple computers
henryhan20, OK, good. Plug both of them in when using the external hard drive. The USB plugs supply power to the device as well as serve as a means to transfer the data. USB ports can carry 5 volts of power (max). If the hard drive is over 4200 RPMs then it will most likely need more than 5 volts to work properly. Try plugging both USB jacks in concurrently.
Hope this helps,
Mark
Oct 05, 2010 | Iomega Computers & Internet
Vox External Hard Drive - Unknown Device???
My drive will do that if the external power to the drice isn't working.
Mar 14, 2010 | RPM Vox 750GB 3.5in USB 2.0 & eSATA...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
My external hard drive wont conect to my computer.
Is this a new drive? has it worked before? the usual sequence is to connect the external drive to a power source first, and then connect the usb cables to the PC. IF you know the usb cables are good and have verified that they are connected properly, try connect to a different usb port on the PC, sometimes ports go bad. If that still doesn't work, the most likely the hard drive has gone bad.
Oct 03, 2009 | Computers & Internet
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
189 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
