Question about Lexmark C533DN InkJet Printer
I have a x6170 and would like to get a copy of the manual. Getting errors codes and do not know what they mean
  • 779 Answers
I have a ir5070 that is getting a E000584 AND E00014. Trying to find a list of error code descriptions but now luck. Anyone know what they mean or why I am getting these?
the error 14 is fixing unit error a dn 584 is finisher shutter error
first disconnect the finisher and solve the fixing error 14
reset the error
copier>function>clear>err>ok and reboot
once the unit is ready to copy run 10 copies to confirm
then connect the finisher and solve the next error 584
Oct 25, 2013 | Canon Office Equipment & Supplies
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
My Lexmark X6170 won't print or partially prints e-mail. Also it won't copy in black but will copy in color? When this happens I get the 0502 error message. Any idea as to what is wrong and how to...
The 0502 error code indicates either a faulty cartridge is detected or the encoder strip (transparent strip) is dislodged from its position. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
What does the error 0502 mean when you are trying to make a copy.I am using the Lexmark X6170 All in One..
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error. This from Clem.
Dec 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error Code???
The 0502 error can be caused by four different issues:
    1. A contaminated encoder strip
    2. An unseated encoder strip
    3. A faulty black/photo cartridge
    4. A faulty color cartridge
Your best look see at the problem would be www.lexmark.com >technical support> Model name >FAQs
May 04, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
I need help on error on my lexmark x6170
Hello, what error are you getting? I am registered as live help, i think you have to download the fixya tool for this. I do not know if it is correct protocol for fixya to pass out phone no's. I charge by the rules, but i refund if i do not solve you problem. lilacgerry xxx
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
When Y make "scanning" from Pc,ist O.K.When Y will copy,sed "error 502 "
Part printing can indicate a few issues. Have you cleaned the heads and cartridges, and wherte they sit manually or with printers own cleaning program?
Error Message
The scanner lock is used to keep the printer from being damaged when it is being shipped. To unlock it, just open the printer and push the scanner lock down. When you lift up the scanner unit, (like what you do to get to the cartridges) the scanner lock is on the left of the underside of the scanner unit. You can get the manual from the Lexmark Website at http://www.lexmark.com/publications/eng/x6100/index.html
Sep 17, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark C533DN InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
