Question about Toshiba Televison & Video
Toshiba 56WH08G tv. no picture, just lines
I have a toshiba 56WH08G tv. can't get a picture, just blue red and green lines across the screen. any ideas?
5 Suggested Answers
  • 375 Answers
SOURCE: No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Posted on Aug 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: sony 65 inch screen tv
Yes the red tube is shorted. I will post a link to the site where I work as they have an entire AV48WP30 with a bad tuner they are selling parts off of including the Tubes. they also provide free info on how to switch out the tubes as a unit which is a fairly easy job. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 21, 2008
  • 1030 Answers
SOURCE: Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Posted on Jun 21, 2008
  • 13 Answers
SOURCE: 3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Posted on Oct 14, 2009
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Green flickering and not lined up with red and blue
well I am not tom but your tv is having a convergence problem only a technician may be able to replace the bad ic inside the set
Aug 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
