No connection on 8231-4 router
I'm trying to connect two pc's wirelessly to a 8231-4 router via 8051 adaptors. 1 connects intermitantly, the other not at all. Any guesses?
    Genius:
  • 1,913 Answers
Hi
check your ip addresses .check that gatway and sub mask is same for both pc.
check both pc have differ name.
try the ping exe in both system anfd check u get reply in both pc.
restart pc
and if u get ping in both pc then if not access any pc of that then run the ip addresses in run .
if u not access any of pc then turn off its firewall or any antivirus firewall.
thanks
pls rate this solution
bye
Posted on Mar 23, 2008
SOURCE:
Bought a new acer 5750 laptop (i5 2nd Gen, 6GB RAM) which connected intermittently to my router. PC World phone help worked through network adapter enable/disable and then eventually a full default...
I would try:
1. updating driver
2. try connecting via Ethernet, if the issue is only wireless connectivity, try using a USB wireless network adapter, if that works means your lappy has a bad built in network adapter.
3. Are you locating laptop too far from router?
Good luck.
Mar 09, 2017 | Acer Computers & Internet
It won't connect with laptop
Here are a few simple things to check:
If your PC is connected via wireless:
- Make sure you didn't go out of signal range
If your PC is connected via wired cable:
- Make sure the cable is secured into your router
If both check out:
- Check the cable between your router and internet modem.
If all connections are solid:
- Try using a different cable from the PC to the router, and from the router to your internet modem. Cables can go bad, and a new one could be an easy fix.
If all else fails, you may have experienced an intermitted connection issue:
- Try unplugging your internet modem and router for 30 seconds, then plug in your internet modem first and after 60 seconds plug in your router.
- Try restarting your PC
If none of those work, contact your Internet Service Provider.
Jul 12, 2010 | D-Link DIR-615 Router
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Upgrade of router giving connection problems
You need to check the settings on the wireless adaptor to make sure it is the same as the new router. If you had set the old router with a password, then you need to set the new one the same way. If the new router is not set with a password and the connection is open and not secured, then you need to change the settings of the computer wireless adaptor.
Jun 26, 2009 | Dell 1450 (D1450U) Wireless Adapter
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
When using the Belkin G router the network connection becomes lost and can not get on the internet. My computer has Vista on it and Belkin says that the router is compatible with the program.
This is possibly caused by your firewall or the wireless security (wpa/wep) on the router if you have set it up.
First of all, if you can connect to the internet via a cabled connection the problem is going to be with the way you've set the router up.
If you've setup wireless security on the router, have you also set it up for your wireless adaptor?.
I suggest you try to connect to the internet via cable to start with, if this works try to connect wirelessly with your firewall off.
If all else fails start from the beginning again.
May 15, 2008 | Belkin Computers & Internet
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Open Questions:
Computers & Internet Logo
60 people viewed this question
Ekse
Alun Cox
