How can I reset the IP address in the Xerox Document Center 425DC so I can configure a new one.
  • 781 Answers
In this manual on page 117 (Network communication set up) it's mentioned how you can change/set the ip address of you printer:
1. connect the printer to the network
2. access the system administrator set up screen (see manual on link above): a. select access b. enter administrator password: #22222 (or the one configured as the one noted as the default password)
3. Access the TCP/IP network setup screens
a. select Print Setups
b. select Protocol Setups
c. select TCP/IP
4. configure the IP address
usually a dhcp server (it may be regular router if your printer is connected to small home/business router the one that provides dhcp services) the one responsible for automatically providing ip address configuration but if you need to manually configure ip addressing select Address resolution and then Static and continue as follows
5. select Ip address and then Edit, proceed entering the ip address that would like to configure manually then save the configuration
6. configure the gateway address set up (need if your printer is required to serve in multinetwork-segement enviroment
a. select gateway address, select edit, proceed to edit the gateway address (usually is the router's private ip address.) and then save
7. configure the subnet mask, selecting subnet mask, then edit, and configure the subnet mask for the ip address of the network where your printer is located.
I hope this helps!
Posted on May 01, 2010
Master reset xerox 8560 printer
Your Administrator Guide book should have these instructions listed for you. It should be on the CD's that came with the printer.
If you have lost/misplaced them, you can download the guides from the Xerox.com website.
The steps below are what I did from my laptop as a Repair Technician:
1. Connect a crossover cable between the PC and system. To print an Event Log or Runtime Log:
2. Verify the system is Ready.
3. Use the system's control panel to enable AutoIP:
a. Select the system Setup menu.
b. Select the Connection Setup menu.
c. Select the Network Setup menu. 5. The page should now print.
d. Select the TCP/IP Setup menu.
e. Set AutoIP to On.
f. Exit the menu so the system is Ready.
4.
NOTE: To print the Connection Setup or Configuration page, select the system Setup
menu.
Reset the system to cause AutoIP to assign a new IP address (cycle power or select
Restart system from the Shutdown menu).
5. After the system's IP address is set, test communication by sending the "PING" com-
mand.
6. If the test fails, install a different cable and retest.
Sep 27, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Reset IP HP2015DN
Hi, not sure why this is coming under the router section. You'd need to post a little more information about the problem. Is it with the IP address settings on your router or those wirthin the printer itself. If its
the printer itself - the problem solution is available here possibly.
But Google Resetting the IP address on
HP2015DN
Details To open the HP Embedded Web Server, type the IP address or hostname of the printer in the address field of a supported Web browser. To find the IP address, print a Configuration page from the control panel of the printer by pressing and holding the Go button for 5 seconds. The HP Embedded Web Server URL can be bookmarked for quick access at a later date. Supported web browsers include the following:
  • Internet Explorer 6.0 (and later)
  • Netscape Navigator 7.0 (and later)
  • Firefox 1.0 (and later)
  • Mozilla 1.6 (and later)
  • Opera 7.0 (and later)
  • Safari 1.2 (and later)
  • Konqueror 3.2 (and later)
The HP Embedded Web Server has the following three tabs that contain settings and information about the printer:
  • Information tab
  • Settings tab
  • Networking tab
Once the HP Embedded Web Server opens, perform the following steps to configure a static IP address:
  1. Click the Networking tab.
  2. Click Network Settings under Configuration in the left menu bar.
  3. Click the TCP/IP tab.
  4. Use the drop-down menu to change the IP Configuration Method to Manual.
  5. Type the new IP Address in the box to change the IP Address .
  6. Change any other applicable networking information, if applicable.
  7. Scroll down the page and click Apply .
  8. Click OK on the confirmation screen and then close the browser window.
  9. Wait a few minutes and then print the Self Test/Configuration page and the HP Jetdirect Configuration page to verify that the IP Address has changed.
Dec 03, 2013 | Computers & Internet
I have a Xerox PPhaser 7760 that is losing network connectivity periodocally. I have reset the network ip, but no go. Is this the formatter?
It is either the card, or the switch/router/configuration. Easiest thing to try is plugging the network cable directly into a laptop. Does it get an ip address? If the printer has a static ip address, try setting that on the laptop if it isn't using dhcp. Can you access the network/internet?
If so its a bad card in the printer. If you can't, have your network administrator look at the port on the router or switch on the other side to make sure its functional and configured correctly.
May 16, 2012 | Xerox Phaser 7760/YDX Laser Printer
How to update a new ip address in order to get my printer print?
I think IP address is not a problem in your printer. You just need to check if the printer driver is install to make your printer work...
IP address is only use to connect the computer to the internet not to connect with the printer. If you have a printer connect to other computer you really need to configure the IP of both the pc to connect each other...
Router will automatically assign IP address of those computer connected to a routers. If you still not connect
Please don't hesitate to ask again and I will give you the step by step to configure your IP address unless your connect with static IP
Sep 20, 2011 | Xerox Phaser 6125 Laser Printer
What usb cable do i need to conect my xerox 425dc to my computer
425DC is a Digital Copier and it cannot be connected to PC, it only can copy, but can't print.
Nov 15, 2010 | Xerox Document Centre 420 DC Laser Printer
XEROX 260 problem
Is the DCHP shut off on the machine? If it is on auto, it most likely changed the IP address.
Print out a configuration page, get the IP address and enter that into you web browser address box.
It sounds like the machine IP address has changed .
Mar 17, 2010 | Xerox Office Equipment & Supplies
Can i print B&W copies on the color zerox 8500 phaser?
Most likely the IP address has reset. If you have your configuration go into network setup, then re enter your IP address, and turn DCHP off, make the IP address static,
Feb 16, 2010 | Xerox Phaser 8500/DN Printer
Xerox 3545 offline
Did you set the IP address to Manual ( Static) to set up a permanant IP address? If you left it on auto and DHCP settings wrong, it will search and reset the IP address. Run a configuration report and check to see if you IP address has changed, I bet it has.
Jan 22, 2009 | Xerox Phaser 8400 Laser Printer
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
62 people viewed this question
jasbo
jasbo
