Question about Sony STR-V444ES Receiver
Receiver str-v444es no sound on headphones or
Receiver str-v444es. no sound on headphones or speakers
    Champion:
  • 287 Answers
Discharge the output circuit! If you don't you will blow a 10 ohm resistor every time. I've worked on hundreds of these receivers I know. They need the output circuit soldered at the voltage driver ic's and quite possibly some capicitors replaced on the digital board. The caps mounted near the heat sinks dry up the fastest. These are nice amps. Larry's Electronics Sacramento Ca. ledstiles@hotmail.com
Posted on Apr 24, 2010
What's your problem?sony v444es 5,1 wont turn on, only clicks the relay on power board non stop
Sounds like your power transformer is bad. You might also check the power board for cracks. This model had a history of that.
Jun 21, 2012 | Sony STR-V444ES Receiver
Hi - I have a Sony V444ES receiver that I have four speakers on A (in house) and two on B (outside). I hooked up a third speaker (rock speaker) for outside use however the sound is very low compared to the...
What's a rock speaker? All you will hear with one speaker on the Rear Right output is the Rear Right channel which is typically for effects and ambience. You DO have a manual, right?
Individual speakers commonly have different responses given the same amplifier input. Where you physically place a speaker once it's electrically connected is up to you. Speakers placed outdoors might not have the sound-re-enforcement of nearby or adjacent walls as indoor speakers do so they will sound weaker.
Jul 11, 2011 | Sony STR-V444ES Receiver
Popping sound at random times out of my AV Reciever/Surround sound system when video is playing.
Clean and tighten all connections. Get a can of spray tuner and contact cleaner from Radio Shack to clean the volume and tone controls if you have access to the body of those controls. Some disassembly required. If this doesn't help, suspect a bad variable resistor in the amplifier circuit.
May 29, 2009 | Sony STR-V444ES Receiver
Stops working after a few mins with cd player playing
One of three things: speaker wire short, shorted/or blown speaker, or a bad output chip. First and easiest way to check is to disconnect all speakers, turn it on, turn it up, and wait. If that's ok, begin connecting one speaker at a time with the unit off, then turn on and play. When you get to the speaker or wire with the problem, it will short and go into protection. Disconnect all speaker wires again and only hook up the speaker that shorted the receiver and test. If it shorts, swap speakers with the same wire and test again. If a different speaker on the same wire causes the unit to short, replace the wire. if it doesn't, you need to test the speaker with a multimeter or disassemble if possible, check the wiring internally on the speaker. Check the impedance, should be 8ohms or 6ohms depending on the drivers. then check for resistance. If your meter says 1... it's shorted and needs to be replaced. Hope this helps
May 25, 2009 | Sony STR-V444ES Receiver
STR-V444ES just hums
Sounds like the output stage is shot.
Here are a few things to try. If there is an option in the manual to reset the unit to factory settings, try that.
If that doesn't work, disconnect all of the peripherals, and select the radio. If you get sound there, you may have a bad cable.
Beyond that I would say the amp needs repaired.
Cheeres
Jan 01, 2009 | Sony STR-V444ES Receiver
Sony Receiver STR-V444ES and Blueray
You might have to go into the players setup and select the output and audio stream options. If it is set for PCM only it will not receive the Dolby or DTS signals if you selected them in the DVDs audio selection menu. There may also be a signal select in the Sony receiver to assign the digital inputs to selected units.
Hope this helps
Cheers
May 08, 2008 | Sony STR-V444ES Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
Sony STR-V444ES Receiver Logo
563 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
