Up software to stb
I am trying to update the software in a standard set top box. I have the software on the computer and have brought the correct adaptor with 9 pin that gos to the stb and usb to the computer. I cant get the software to transfer. It is ment to start on it own once I turn the stb on but it will not. I have the software all ready and connect to the stb. I press start and then turn the stb on but nothing happens. I am following the instruction that are written for the software. Anyone have any idea what I am doing wrong
  • 5 more comments
  • paulatorpy Apr 24, 2010
    Hi thanks for your responce. I have unzipped the files and followed the instructions on the help section. It tells me to start the update manager file and load the software throught that. Then to put the files that I want to put on the sd box into that update manager and press start then turn on the sd box. I do all that but cant get it to transfer.
    I have just tried to unzip it onto the g drive as that is the address for my adaptor and it tells me it cant do that so somehow I have to use the update manager. Just not sure how
  • paulatorpy Apr 25, 2010
    I know it was only an example that is why on the last post I said it was the drive of my adaptor
  • paulatorpy Apr 26, 2010
    Hi the make is digiccrystal, Model # SDT-2500P
  • paulatorpy Apr 27, 2010
    There is no drop down menu or settings etc in the update manager file.
    The adaptor is the right one. have checked
    President:
  • 1,768 Answers
This may not be the correct adapter.Pin outs may not be correct.
Call the manufacturer and talk to tech support and verify the correct adapter and pin out for this unit.
Posted on Apr 26, 2010
  • 4,889 Answers
Ensure that you have extracted the contents of the firmware from the exe self extractor or zip archive. Another possibility is that you probably have the software contents in a folder. It should be in the drive directly as files. For example your USB drive is G and its in G:\update\update.bin
then move it to G;\Update.bin
Posted on Apr 24, 2010
  • 2 more comments
  • eagle338
    eagle338 Apr 24, 2010
    The G drive thing was just an example. Replace that with the drive letter of the USB drive or any other device you are using to upgrade.
  • eagle338
    eagle338 Apr 25, 2010
    Ok. You have the files on your USB driver right. Just select the update files where ever they are then press Ctrl and X on your keyboard. Now go to the location G and hit ctrl and V. That should do the trick
  • eagle338
    eagle338 Apr 26, 2010
    If it does not auto launch most devices have an option to launch the update process manually. Please let me know the make and model of your STB so that I can guide you with the same.
  • eagle338
    eagle338 Apr 27, 2010
    Not much info about this model in our database. Anyways look under Menu-> Setup and see if it has an option called update. Setup is also given as System or setting is some models. Try it and let me know.
    Sai.
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Everything works fine. Just want to know what this abbreviation is: STB Refw Design. STB is Set Top Box..what is the rest? Thanks
The rest is "Reference Design". Only a few companies created the set top box chips/electronics plans. These companies license their designs to the various vendors/builders of STB boxes.
I hope this helps.
(Sometimes you'll see a reference to the STB RDK. This is a set-top box reference design kit. It's pre-packaged set up for the manufacturers.)
May 08, 2015 | Televison & Video
Akko
http://www.awa.com.au/AIKO---Set-Top-Box/default.aspx
You can download the manual here. The factory reset is within. If you don't find it, let us know I will tell you how. Best to look for yourself as your set top is a diff one than mine and I want to be sure.
Jun 10, 2013 | Computers & Internet
I bought a samsung TV from Australia and brought the TV in the Philippines.The problem is there is only three coutries listed on the menu,Australia,Nwe Zealand and Singapore.I tried to make a search for...
Sorry to inform you the audio carrier frequency in your country is different from the the other three countries you have mentioned. Don't loose heart you can always purchase a local Set Top Box and connect the AV out ( Yellow/ Red / White ) of the STB to your TV's AV in. There are no carrier frequency issue here. Or even better buy a Digital Set Top box and enjoy good sound and picture !!!
Mar 28, 2011 | Samsung Televison & Video
No problem - I hope!!!!\Just need to know if Direct TV is compatible.
DirectTV should be compatible with all TVs. You will need to have a set-top box installed that works with your TV. For example, if you have HDTV and you want HDTV quality TV then you will need a HDTV STB. Otherwise if it is a standard TV then their normal STB will work. You will have no issues.
Mar 10, 2011 | Televison & Video
I just got a WTV1903 TV from a friend. I have cable but the TV seems to only receive up to Chnnel 22. Is there a way to get more channels?
You should have an auto programming selection on your TV. In the setup menu. But Does your cable have a set top box? If so Run cable line into STB and out to the input of your tv and if you use a coaxial cable you should be able to put your tv in CH 3, and use your stb remote to change channels. Hope this helps
Aug 07, 2010 | Televison & Video
I need to reset a Aiko STB255 Standard Definition Set Top Box to factory settings. I have no manual. Could someone with a manual give me the steps to take. It was working fine but I tried to tune it to...
LOAD FACTORY DEFAULT (from owners manual) Reset the STB back to factory settings 1. Enter 'Tools' menu. Highlight 'Load Factory Default' 2. Press the 'OK' button. You will be asked to input the password 3. Input the password using the numeric buttons (default is '0000') 4. A confirmation window is displayed. Highlight 'Yes' to confirm. STB will return back to factory settings and clear all channels 5. Press the 'MENU' button to exit
Dec 26, 2009 | Televison & Video
Hi, I got one Aiko set top box(STB 255) but
Connect video cable to Y: port. You will see all the menu again. change Video output back to CVBS. (I did the same thing, when i connect VGA cable to y(Green coloured port picture was blued but after few attempts i got clear picture)
Dec 05, 2009 | Televison & Video
Manual for alba stb v3.8 set top box - required in order to retune channels.
please download the user guide from this site
http://www.quick2view.co.uk/
Hope it helps you
Thanks
Oct 01, 2009 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
