Question about Intel D850MV Motherboard
After switching on the system, power is in mother board, processor fan and cup fans are running but hang position(no display, keyboard and mouse are inactive-no action) sometimes it works fine -- cause&solution for this please. . .
    Sergeant:
  • 279 Answers
Try to replace the memory cards (mostly common problems caused by memory card defect)
Posted on Apr 24, 2010
P4M900T-M2 Motherboard cant display anything on display, Power supply fan & CPU fan is running. I changed processor, RAM, Power Supply, Capacitors around CPU, but am still getting nothing on the...
It seem that changing the mother board was needed to confirm as there seems to be a problem related to non communication of the mother board with the CPU, RAM and sections.
Swap and confirm.
Aug 08, 2011 | Computers & Internet
No display in monitor when i switch on my pc, i can see display on monitor after switching on the cpu for 5 or 6 times
Hello sir, hi, check out the following: I'm assuming the things that you may have forgotten.
1. is the 4 pin 12V Molex power connector connected to the mother board? 2. did you use a a good and tested memory module? have this module tested first on another PC. 3. Is your memory slot free of dust and dirt? if not clean it up. 4. is you power supply fan and processor fan spins when power is on? 5. Try powering ONLY the motherboard connected to a video display, no sata/ide cable with a tested memory installed. 6. try another Power Supply box. 7. Is your processor mounted properly? 8. when you apply power look at the keyboard lights, 3 lights initial power on then 1 light the numlock led is on. 9. do you have a plugged in usb device, remove this device as you power on the motherboard. 10. do every thing again and double check.
if all else failed, bad mother board. have this checked by a technician.
Oct 18, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Intel mother board power light is on... but processor not working.. when switch on my cpu. the mother board powerlight displayed.mother fan is only one time run for sec.. processor not on
This is was with me too. I know how to fix it. Remove all cables from your cabinet, i mean like keyboard, mouse, moniter etc. Remove your ram too. Then press your power button from 30 seconds. wait for 10 mins plugin all cables and turn it on. Hope it works for you.
Best of luck.
Jul 22, 2010 | Intel D945GCCR Motherboard
Computer not working
Try to reseat the connectors on the mother board.
Feb 21, 2010 | NEC (190300) 235-Watt Power Supply
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
REPLACED MOBO INTEL D845EPI/845GVSR EMACHINE 2.5 P4 REPLACED PROCESSOR... NO DISPLAY OR KEYBOARD RECOGNIZED, NO BEEPS NOTHING BUT FANS ARE RUNNING AND LIGHTS ARE ON?
1.*********** Board not supporting Your Processor.
2. Try With Lower Speed Processor
3. Mahe sure that Mother Board is Working or Faulty.
4.Check the ram twice
If it HELPS RATE ME!
Jun 24, 2009 | Intel Desktop Board D845EPI Motherboard
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Keyboard and mouse problem
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
May 25, 2008 | Intel D101GGC Motherboard
Intel D850MV Motherboard Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
