Question about Microsoft Xbox 360 Console
I have 3 red lights showing on my xbox. I have checked all the power cables and there are ok. What can I do
    Scholar:
  • 161 Answers
No not open it if it has never been opened before. Microsoft will fix it for free.
Posted on Apr 25, 2010
My son has turned on his x box which seems to show the normal green light but cannot see anything on any of the tv's in the house. This worked yesterday but I put it in the cuboard last night and now it...
check the video cable that hooks to the xbox... it has a switch for normal tv and hd tv.....and also try a different input on the tv... but first check to make the cable is hooked to the tv correctly...red 2 red, yellow 2 yellow , and white 2 white.....if all of that ok then xbox quite...
Feb 04, 2011 | Microsoft Xbox 360 Console
Xbox switches on ok but no sound or vision output to tv?
If there are no red flashing lights around the power button, check your cables. The xbox doesn't like to be turned on without the A/V cable plugged in, so it might have come loose from the TV. I'd check the connecting point to the TV, and the TV settings (make sure it is set to the xbox input, and not, say, a DVD/cable box input)
The GPU (graphics chip) has been known to go bad quite easily on the xbox, but I wouldn't want to tackle repairing that unless you see the red lights blinking (which is a sure indicator that it needs to be repaired)
Nov 11, 2009 | Microsoft Xbox 360 Console
Xbox 360
If you are getting nothing when you try to turn it on, no lights or anything...then check your power converter to see if it is supplying proper voltage. This can easily be done with a multimeter.
If the power converter is ok, I would call xbox and see about getting warranty work done.
If you are getting red lights where it shows what controllers are hooked up (they are green when working correctly), then you will most likely need warranty work.
If you xbox turns on but you are getting no picture to your tv, I would check it on a different TV to see if possibly the input ports on TV are fried.
Also check to make sure that all connections like power cord, RCA cables are hooked up correctly and firmly in their socket.
Hope this helps.
Sep 14, 2009 | Microsoft Video Game Consoles & Games
IGOT 3 RINGS OF DETH
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 14, 2009 | Microsoft Xbox 360 Console
I have 3 red lights what is the problem !!!!!!!!!!
Here are things to try:
Apr 05, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow this steps:
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow the steps below, Hope this helps
Dont worry shipping and handling will be covered.
Apr 03, 2009 | Microsoft Xbox 360 Elite Console
Xbox red green flashing lights
r they all red or only certain ones the most common thing to check first are the av cables/hdmi cable from the xbox to the tv.. if they are loose on the xbox it will show the red ring in a sequence make sure their tight...if this does not fix it YOU HAVE THE RED RING OF DEATH its either overheated or you have a bad disk drive or something internal....you will need to call microsoft
Feb 23, 2009 | Video Game Consoles & Games
Three red lights
three red lights (no error message) - two reasons for the red lights: hardware failure or power supply unit failure.
when the three red lights is showing check the light on the power supply unit. if the light is green you console is experiencing a hardware failure. you need to send the console to MS service center or if you have no MS support in your country look for someone who knows how to repair the console or go to xbox-scene.com and look for information on how to repair the console yourself.
if the light is orange, red or no light at all, there might be a problem with the power supply unit. disconnect and reconnect the power cables from the 360 and reconnect them again. if there is an inter-cooler connected at the back of the console, remove the inter-cooler and turn on the console without the inter-cooler. try also a different wall socket and if the light on the power supply is still orange, red, or no light when you turn on the console you need to replace the power supply unit.
Jan 18, 2008 | Microsoft Xbox 360 Console
4 Flashing red lights
unplug all cables from the back of the XBOX and then plug them back on (making sure that they are connected) and then power up the 360.
from past experiences, I've only seen the 4 flashing red lights if the AV connection is not secure.
Good luck
Nov 19, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
