Question about LaCie (300951U) 500 GB Hard Drive
I got a Lacie external hard drive it was completely full,but now even after i delete some of the most heavier files it still no space ,any idea what i need to do? thanks
  • 251 Answers
Hi, try emptying your recycle bin and defragment the drive , that usually fixes the problem .
hope this helps
Posted on Apr 24, 2010
Delete lacie files
Please specific what OS you are using. Also is the drive internal or external.
Sep 24, 2014 | LaCie Computers & Internet
Message on LaCie Hard drive says Hard Drive is full, but I cannot clear
Ensure that your system drive C: is not full, or you get similar troubles. When the external hard drive start giving this kind of troubles usually it is becouse of a bad FAT, the only solution is formatting the hard drive. Store your 15 GB elsewhere and format it.
Jul 29, 2008 | Computers & Internet
My drive is full, I deleted files but it is still full. Can I compress the data
OK... have just the answer for you but you MUST have room enough for one more tiny program...
CCLEANER
Get it FREE from the links below!
Anthony
https://www.piriform.com/ccleaner/download
and the TUTORIAL is here:
How to use CCleaner tutorial Clean your Computer Free Easy
Dec 02, 2017 | LaCie 80GB Mobile Disk USB 2.0 80 GB Hard...
Cant delete files off external harddrive. files disappear but no space is freed up? lacie porche fa
this sometimes happens when you delete files partially. Deleting file normally will send it to the Trash (MAC) or Recycle Bin (PC) . The file is not really deleted at that point. Make sure to empty the Trash or Recycle Bin and the space should be freed.
If this does not work, copy all needed files somewhere else, then format the drive.
Regards,
Jan 02, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Can't copy large files
check the jumper of the disk, (turne pc off)..some disk use small jumpers for protection...............if that is not the problem..then some programes may do that (antiviruses...linux os)
Dec 30, 2009 | LaCie (300740) 160 GB Hard Drive
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
`lacie hard drive
empty your trash. and youu be pleased
Sep 03, 2008 | Computers & Internet
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Information used- capacity used and available
Re: deleting the files, did you drag the files into the trash bin and then empty it? The files don't actually leave your drive until you 'Empty Trash' on your mac's doc. Hope this helps, not sure about your startup disc problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
See all LaCie (300951U) 500 GB Hard Drive Questions
LaCie (300951U) 500 GB Hard Drive Logo
93 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
