Question about Toshiba Satellite A105 Notebook
No operating system displayed only the trade marks appear..
Hardsk works good and d memory....
    Sergeant:
  • 252 Answers
Purchase a Operation system CD & install OS in several minutes.
Thanks.
Happy to help you.
Posted on Apr 24, 2010
Jandy rs4 indoor control panel lights up but nothing displays
trade controllers if when switched problem moves bad controller if problem stays inside bad wires or plug
Aug 18, 2012 | Jandy Aqualink Rs4 One Touch Control...
Hello, I have recently bought a Leica Digilux 1 but I can't use it since it always marks "Memory Card Error". I have tried with three different memory cards and that sign keeps on appearing....
First make sure that any pics on the cards are safely downloaded to your computer. To get the cards to work in the Leica, you must format them in the camera. This will erase them and set them for the operating system of the camera.
Aug 17, 2011 | Leica Digilux 1 Digital Camera
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
How do i repair a blue screen error readinng 0x00000035 (0x00000000 0x00000000 0x863BDAB8)
you must setting back your Display configuration with safe mode in there you can setting your display screen back to normal again and then restart your computer.good luck
Apr 28, 2010 | Computers & Internet
The system appears to powerup properly but the screen only displays the windows pointer. The rest of the screen is black
Does it boot with a CD or with a floppy?
If so, it's time to redo the boot sector on your HDD
JOAT
Oct 16, 2009 | Dell Dimension 3100 PC Desktop
RAM Upgrade
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | IBM PC 350 PC Desktop
Can't copy pictures from sd to frame
Follow these steps, Selecting all:
1. Press whenever pictures/videos are displayed (slide show, video, single picture). 2. Press to highlight Select all, then press OK. A confirmation screen appears, then your picture display reappears. A check mark is displayed on all pictures/videos in your current location. 3. To remove all check marks, press , highlight Select / Unselect all and press OK. 4. Highlight Unselect all and press OK. A confirmation screen appears, then your picture display reappears. All check marks are removed. Also, you may download the user's guide at www.kodak.com/go/manuals
Jan 22, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Toshiba Satellite A105 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
