Question about Toshiba Satellite R10-S802TD Tablet PC
My Screen!!! Hey guys, recently I have had a problem with my satellite 1100 screen. Its flickering and the bottom half of the screen is appearing on the top and the top half is appearing on the bottom. HELP I need my laptop!!! --------------Tom Johnson--------------
Thanks it is working but my touch pad is not!!!!!
Posted on Apr 06, 2008
    Genius:
  • 1,913 Answers
Hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Posted on Mar 23, 2008
SOURCE:
Why does my kindle fire flicker and revert to random pages or page back to the beginning of a book?
Kindle Fire: 12 Common Problems and How to Fix Them ...
www.digitaltrends.com/mobile/kindle-fire-hd-problems/
Mar 6, 2013 - If you are experiencing some Kindle Fire HDX problems then you might just ... Try deregistering your Kindle Fire HD by swiping down from the top and tapping More > My .... by Simon Hill: Updated to add sound problems, screen flicker glitch, ... Lion Captures A Baby Baboon But Does The Last Thing You'd ...
Amazon.com: Customer Discussions: Screen Flicker on Fire
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 17, 2011 - The Fire's screen should not flicker; if it does, call Amazon CS and ... *update* i called about my flickering kindle fire. customer service was ... Kindle Fire HDX 7 inch - Screen ...
Dec 26, 2013
will kindle fire hurt my eyes?
Nov 1, 2011
More results from www.amazon.com
Dec 29, 2015 | Tablets & eReaders
My Kindle was fine last night before last. It froze when I got ready to read it today. I tried rebooting it but when it came back on half the screen is visible the bottom half stayed frozen. Is there a...
It could be a hardware problem. Half a screen not working doesn't sound good to me. I have a PaperWhite Kindle. I had another Kindle I dropped and it came up like yours, with half a screen showing the picture and the other half the screen showing white. It's now a paper weight.
You can try a total reboot by holding down the power button for about twenty seconds. Mine hangs up every couple months and the touch screen stops responding and the reboot by holding down the power button for about twenty seconds fixes it every time. It takes a few minutes. You have to sit there and watch the slow progress bar fill in as it goes through the re-boot process.
If this doesn't work, you might try removing the back cover, disconnecting the battery. Letting it set for minute or so and then reconnect the battery, re-install the back cover and try a normal short-power button push first and if nothing happens, follow it with the long power button push.
Mar 01, 2015 | Tablets & eReaders
Blinking screen off
First, restart your iPad.
If the blinking continues you will have to take it to an iPhone/iPad specialty repair shop because the problem is it has probably been slightly damaged some way and the blinking screen means that the screen has been damaged in one area
Sep 02, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Screen not readibloe on top half two different ads appear
it may be solve by changing the gadget screen and this can be solve by changing the screen, but the better option is just consult the service provider of your device.
Aug 02, 2011 | Amazon Kindle 1
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Use the following steps to enable screen rotation lock:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
460 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
