Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Saniflo macerator pump to toilette cauase mcb to trip even if not being used it has to be switched off now, is this likely to be a problem with the macerator itself or wiring?
  • 251 Answers
Hi, the usual cause is damp or water in the connector box on the unit .
hope this helps
p.s. wear gloves
Posted on Apr 24, 2010
Saniflo keeps tripping the breaker
It sounds as if there is a fault with the macerator motor. Are you saying that the saniflo is causing the rcd / fuse to trip, so you reset it, and it trips out again? Can you hear any noise from the saniflo before it trips out? If not or there is a loud humming noise it could mean the unit is blocked and the motor has stalled. Can you detect any unwanted smells coming from the unit? if so there is a good chance that there is a leak which may have strayed into the internal wiring and tripped the supply.
Jan 10, 2015 | Saniflo Home
Every time the float operates the switch to on the fuse trips out?
It sounds like the impeller for the grinder pump has something fowling it and you will need to pull the pump or at least clean it out.
Mar 04, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
Saniflo Top: Pump
indicates perhaps a faulty pressure switch. otherwise: this happens often in hard water areas due to build up of limescale. Use a descaling agent (acidic) to clean the saniflo - can be introduced via the toilet bowl.
Apr 02, 2010 | Saniflo & Saniplus& Macerator Pump
I have a turbofush P macerator and the pump no longer switches off automatically after grinding and flushing has occurred
turboflush uses a pcb mounted pressure sensor to switch the unit on/off. there is a small tube that connects to this unit. make sure that is ok and connected. otherwise its a new pcb i'm afraid. look online more info from saniflo-pumpshop.co.uk
Mar 17, 2010 | Saniflo & Saniplus& Macerator Pump
Describe your Saniflo &
your p-trap is dry . the guy who did it probably didn't vent it properly, and it's being syphined. call him back to fix it.
Sep 15, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Aug 03, 2009 | Saniflo & Saniplus& Macerator Pump
Can a saniflo 003 toilet be installed with only the 005 tank, or does it need a macerator?
depends on how you use the unit. the macerator chews up paper and other unmentionables.I would suggest you use it as one unit.
Jul 12, 2009 | Saniflo Sanibest macerator with multiple...
Pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
Jul 05, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
368 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
