Question about C-Technologies C-Pen 600 Handheld Scanner
Install C-Pen 600C in Vista
I'd like to install C-Pen 600C in Vista. Is it possible?
Software download for cardscan 600c for windows vista
In order to install Cardscan 600c on Windows Vista you need Cardscan Software version 8. Here is a link to the software along with the serial number you'll need for the activation. Please first install the software and then plug the device directly into the PC.
http://www.cardscan.com/downloads/fb/cs805exec.exe
41-0000-00274478
I hope this will help!
Kind regards,
^ST
DymoSupport
Jul 15, 2015 | CardScan Office Equipment & Supplies
Tip
How to install vista from pendrive
Its very difficult to install windows vista if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows vista DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pen drive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows vista DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows vista DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Microsoft Windows Vista Ultimate Edition
How to install Cardscan 600C on Windows 8 without driver CD
In order to install Cardscan 600c on Windows 8 you need Cardscan Software version 8. Here is a link to the software along with the serial number you'll need for the activation. Please first install the software and then plug the device directly into the PC.
41-0000-00274478
Kind regards,
^ST
DymoSupport
Jun 07, 2015 | Corex CardScan 600c business card scanner
C pen driver 600mx
Will C-Pen 600C work with Windows 7 and Windows Vista? software for C-Pen 600C (C-Win 3.24) is not compatible with these operating systems.
however you can install http://download.anoto.com/ctech/C-Win_3_24.exe and use software with "Microsoft XP Mode".
Apr 22, 2014 | Microsoft Windows 7 Ultimate for PC
Lowrance AirMap 600C won't lock on satellites
Reset the AirMap 600:
1. Turn unit off
2. Press and hold PAGES and PWR until you get the "warning, do not rely..." message and then release the buttons.
If it still won't acquire position, install the latest update from http://www.lowrance.com/en/Products/Aviation/AirMap-600C/Downloads/AirMap-600C-Software-Update/.
If it still won't acquire, and it has a clear, unobstructed view of the sky, and the batteries are good, there is a malfunction and it will require service or replacement.
Jul 13, 2009 | Lowrance Iway 500c GPS Receiver
I can't get hp deskjet 600c to work with Vista. Am using a IEEE 1284 to USB cable. HP site states Vista driver will automatically recognize and install printer, but my computer does not. Print manager...
The drivers for the 600C should be there in Vista, it should directly install the drivers. Check if the drivers is not in offline mode, right click and turn it to online mode. If the drivers were installed automatically when you plugged the USB cable, then the USB cable should be good enough.
Jan 27, 2009 | Office Equipment & Supplies
C-Pen 600c Can't turn it off !!!
sounds like when you release the button the button is activating again and turning it back on clean it out with rubbing alchol be sure not to use it until its 100% dry!
Jun 13, 2008 | C-Technologies C-Pen 600C Handheld Scanner
Hiiiii
If your system is not detecting Please install usb driver for your system then you may need to install driver for the pen dive( If its Xp or Vista No need)
Mar 05, 2008 | Computers & Internet
C-Technologies C-Pen 600 Handheld Scanner Logo
61 people viewed this question
Top C-Technologies Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a C-Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
