Question about Kenmore 75101 Wall/Window Air Conditioner
I need a wiring diagram for the kenmore 75101 thru wall a/c unit a complete diagram all componets listed
  • power_enterp May 11, 2010
    what is the purpose of the drawing ? repair? wire up?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
The pigtail cord has a hot leg and neutral for 115 volts, or if 230 volts , 2 hot legs of 115 volts & and a ground. The Hot leg (if one) is routed through the switch. The switch seds power to the compresor and fan motor. The neutral or other dside of power is the side all loads will terminate to have both sides of power as a AA batt in a flashlight, both ends of the batt must be present, as this is all there is and you willneed to trace wires a diagram is never required.
Posted on Apr 24, 2010
    Problem Solver:
  • 9 Answers
Hope this helps
I need a wiring diagram for the kenmore 75101 thru - 8_19_2015_4_36_52_pm.jpg8_19_2015_4_36_54_pm.jpg
Posted on Aug 19, 2015
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I need an installation manual for ac 75135 This is a closeout.
It is the either the fan bearings is going out of the motor or you just might clean the fan blades it the fan blades has any play on the shaft probably the bearings are going out to the motor.
Jun 03, 2010 | Kenmore 75101 Wall/Window Air Conditioner
Does the outside vent need to open or closed for
Close the vent to get the most cooling...
heatman101
Jun 02, 2010 | Kenmore 75101 Wall/Window Air Conditioner
Cannot find vent control lever
I too cannot find the Vent Control Lever for my Kenmore 580.kenmore air conditioner model number is: 580.75251800. I DO see in the owners manual WHERE the lever should be, however, I do NOT see the vent control lever, nor ostesibly WHERE the vent can be, bought the unit new in 2009 from SEARS, anyone have any ideas?
Apr 23, 2010 | Kenmore 75101 Wall/Window Air Conditioner
Kenmore 580 75101 a/c will not turn off. All the lights are off but something inside keeps running, though it's not putting out air.
Check if pulling out the plug stops the noise. If the noise is still present you might be hearing the freon in the system running inside the metal tubes. It could also be the expansion valves still moving. This may be caused by incorrect freon pressure, leaks or faulty valves. If the noise goes out after pulling the plug, you might be hearing the compressor. This could be caused by faulty wiring or switch.
Aug 04, 2009 | Kenmore 75101 Wall/Window Air Conditioner
Safety plug on unit keeps popping out after running a while.
You have a short somewhere. With any luck you might have a wire come loose from the compressor.Side the unit out and remove the cover. Inspect the terminals on the compressor. if they are all fine then check the run capacitor. If it is swollen or leaky then it has failed. If that is fine then i would next check for continuity between each pin to ground on that conpressor. if you have any continuity on that then it is compressor replacement time.
Apr 09, 2009 | Kenmore 75101 Wall/Window Air Conditioner
Kenmore side by side md# 106.59099990
the most likely cause of this is the starter or what is called the overload/relay on the compressor. this is the piece that sets on the compressor and has the wires going to it. There may be some sort of a hold on clip. Remove it and the componet pulls off. Mahe a diagram of what you are doing so you remember how it goes back on. ALSO- unplug the unit before you touch it!
Dec 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 75101 Wall/Window Air Conditioner Logo
461 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
