Changed my ink cartridges and then got up printing error came up can you tell me what is wrong
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message
Probable Cause
No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly.
Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink
Ink cartridge error - - >
There is something wrong with the ink cartridge.
Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing.
Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place.
Scanner error - - >
See your documentation and call Service if necessary.
Press
the On button to turn off the EPSON CX3200. Check the transportation
lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If
the error message still appears, contact your dealer or EPSON.
Printer error - - >
Press
the On button to turn off the EPSON CX3200, then press it again to turn
it back on. If the message still appears, contact your dealer or EPSON.
printer error see your documentation and call services
