Question about Sony Ericsson W700i Cellular Phone
There is problem of network in my mobile
When you Galaxy Samsung Say Not registered on network when you trying to call someone How to fix that
According to WikiNix.com:
Step 1:
First, go to Settings.
Step 2:
Then go to Wireless and networks.
Step 3:
Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks). Watch video to understand and solve this issue easily.
Step 4:
Now tap Networks operators.
Step 5:
After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Updated Fix 1. In Mobile Networks, set Network mode as WCDMA only and restart your phone. After restarting, follow above steps. That.s it (Updated on 12 September 2014). "
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
May 10, 2015 | Samsung Cell Phones
Blackberry z10 network setting
try checking if airplane mode is off Tap mba1334327736541_lowres_en-us.png Settings > Network Connections > Mobile Network.Set the Mobile Network switch to On. After you finish: To turn off your connection to the mobile network, set the Mobile Network switch to Off.
Aug 28, 2014 | Blackberry Z10 24Gb Black WiFi Touchscreen...
Hi T-Mobile, pls i have a brand new Nokia lumia 521, type RM-917, EMEI 355913057656196.that was bought in the U.S and now sent to me in africa(cameroon) but i cant use the phone becouse i don't have the...
If the sim came with the phone that is an American phone you need a sim for an African mobile phone network in your country or you need to contact the American mobile phone network provider to get the unlock code. The phone may be locked onto a particular USA mobile phone radio network and you would need to know what network it is locked to. There are web sites that offer to get the unlock code on the internet for mobiles locked on a particular mobile network but I have not had experience using them and do not know how successful they are to try and unlock a mobile from a particular mobile network. You will find this out when you change the sim card in the phone for a local African mobile phone provider in Africa
see http://www.youtube.com/watch?v=dC0KKX-2bn8
with an USA sim card and USA mobile network provider you will pay lots of money in Roaming charges which you would wish to avoid by using a local African mobile provider.
A local provider may be able to help you unlock the phone from the particular mobile network if it is locked on a USA mobile network.
There must be a mobile network provider in Africa that can work on your mobile phone type for it to work with that mobile network providers correct sim card.
Another source of problem could be if the phone has been reported as stolen the IMEI may not work due to being blacklisted and disabled.
Jul 04, 2014 | Cell Phones
How can I unlock sim network it has been completely locked
Hai, Unlocking is the process of releasing your network lock. So only you can able to use all network in your mobile. Some mobile are locked by the network provider. Unlocking will be used to remove that network provider lock.This type of unlocking can be done through codes. This mobile unlocking code provided by network providers or online venders like Wickedunlock.com . They will help you to unlock your T-Mobile and send the code to your mail along with instructions.
May 02, 2014 | T-Mobile Concord
Nokia e5 network
What's your Network Provider?What's your Nokia E5 Network Exact Problem?
1.Is your mobile Network has Lower signal or No signal?
You can try to switch OFF your mobile and switch ON to check Network strength.
2.Is your mobile display show "NETWORK ERROR" message?
You can try to check the below instructions:
1.Reinsert SIM in your mobile
2.Insert another SIM in your mobile
3.Insert Your SIM into another mobile
3.Is your Mobile Network Locked?
You can easily unlocked your mobile by using unlock code.You can contact your service provider and get the code.If they will not provide the code..You may look at safe and trustworthy online third party code providers, like Unlock-Zone.com where they will provide permanent unlock code with free unlocking instructions..Then you can use this code to easily unlock your mobile.
Apr 25, 2014 | Cell Phones
Network problam
What's your Network Provider and Exact Problem?
1.Is your Samsung GTB7722 Network has Lower signal or No signal?
1.Reinsert the SIM your mobile
2.Another SIM insert your mobile
3.Insert your SIM into another mobile.
You can easily unlocked your mobile by using unlock code.You can contact your service provider and get the code.If they will not provide the code..You may look at safe and trustworthy online third party code providers, like Mobile-Unlocker.com where they provide permanent unlock code..After you get the code visit MobileUnlockGuide.com for free instruction on how to use that code to unlock your mobile.
Apr 16, 2014 | Samsung GTB7722
Gt 3310i network poblim
What's your Network carrier?
Exactly what's problem your network?
Some problem detect in network for:low network signal,don't signal show in mobile, mobile shows network locked and so on...
If your mobile have network locked..I give solution to you..You can easily unlocking your Samsung GT 3310 from network locked, by using unlock code..There are many ways to get the unlock code from your service provider, shops, Third party providers and so on..You can try at this site www.Unlocking4U.com here specify your Network provider,Country and IMEI..They will help to provide unlock code to you..
Mar 09, 2014 | Health & Beauty
Locked network, I need a code
WHAT IS your network?contact your network provider..
Sep 13, 2011 | Cell Phones
What is network selection? which is better automatic a or b ?
Most GSM handsets offer a choice to select a new network, automatically or manually. The default setting, in most cases, is automatic, which instructs your mobile to automatically connect to the strongest network signal available. As you move, the handset will continually monitor the available networks, and keep you connected to the strongest one. In a manual network selection setting, your mobile handset will detect if there is more than one network present and offer you a choice. If you then select one network, your mobile phone will remain connected to it regardless of the alternative networks available. You may prefer to remain connected to one network if it offers cheaper outgoing call charges. To manually select networks please refer to your mobile phone user manual for instructions. Your Jersey Telecom SIM card can store a list of your preferred roaming partners. If you have an automatic network selection setting, and there are two networks of equal strength available, the mobile phones will connect you to the one that is highest on your SIM card’s preferred list. The list can be edited by using the appropriate menu on your mobile phone. Check your mobile phone user manual for details.
don"t forget to say thank's
Mar 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Sony Ericsson W700i Cellular Phone Logo
15 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
