Question about Target Portable Masonry Saw PS1455 Horsepower: 5 1/2. Blade Guard Capacity: 14
I need a wiring schematic for a target masonry saw, model gm 2051 with a baldor 5 hp 240v motor. my present motor does not have any wires connected except for the on/off switch. thanks for any help.
2 Suggested Answers
  • 33 Answers
SOURCE: need a wiring schematic for a dual voltage masonry
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Posted on Dec 14, 2009
Testimonial: "ty this should help"
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a Baldor 1022W grinder but i'm not sure how it is wired. I've tried looking for wiring schematics but have been unsuccessful. All I need to know is how to tell if the grinder is wired 115V...
first off what does the plug look like? that would be one clue and also usually under the bottom plate there is a wiring breakdown. Let me know if you need more help
May 12, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
My target wet saw, on top of the motor has a part in it that overheats due to getting wet, there are two wires soldered. one labeled E, going to the motor,it seems to be an overload device possibly? I was...
We are currently experiencing a problem with the target TA10100 wet saw. It will start up and immediately shutdown. The local authorized tool repair said that the part encased on the top of the Baldor motor is called a capacitor. we have yet to find out if this is the cause of the problem. Hope the information helps you because so far it hasn't helped us.
Mar 08, 2010 | Target Saws
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Jan 13, 2010 | Target Portable Masonry Saw PS1411S...
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
enter model number
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
Compatability with US 240v 60HZ 1phase wiring?
It should work OK The US system is 240V single phase (split) into two 120v branches. Aussi system is hot on both sides, with a center ground (a virtual ground system) Connect the 2 main wires (usually brown and blue) to the 240 (black and red), and connect the grounds (Green/yellow to green), and leave the neutral wire off.
Jun 14, 2008 | Saeco Royal Professional Espresso Machine
Target Portable Masonry Saw PS1455 Horsepower: 5 1/2. Blade Guard Capacity: 14 Logo
301 people viewed this question
Top Target Saws Experts
Tom Chichester
ray gallant
Are you a Target Saw Expert? Answer questions, earn points and help others
