Question about EliteGroup P6STP-FL Motherboard
CMOS Checksum error - Defaults loaded
Hi
I Am getting the subject matter come up on my screen each time I switch on the PC. Then it also says:
Warning! CPU has been changed.
Please enter CPU Speed CMOS setup.
I have the motherboard CD and I know how to get to my BIOS & CMOS pages, but need some instruction to correct this error.
Kind Regards
Sharon
  • malzard Mar 23, 2008
    Please could you direct me:
    Do I change the actual speed of CPU in:
    * Standard CMOS Features option
    * Advanced BIOS Features Setup Option
    If you could give me a more advanced direction I would appreciate it.
  • 255 Answers
step 1: 1st change your Cmos battery
step 2: goto cmos setup, change your cpu speed, what speed of cpu are you using and what mhz of
your cpu.
step 3: save your setup and restart your computer... i hope u will get rid of this problem.
Note:-
if you give me your system detail i can explain more better than this...
what is your system configuration:
P1 or P2 or P3 or P4 or Intel Dual Core or Core 2 Duo
Cpu speed : 150mhz or 200mhz or 500mhz or 800mhz or 1Ghz or 2.2Ghz or 3Ghz
Mother board : Intel Pentium or Sis or Via or Mercury or Asus etc....
mail me your configuration : mohammedehsanullah@gmail.com
Posted on Jun 17, 2009
  • 655 Answers
When the CPU speed stored in BIOS and the actuall speed of CPU differs then this error comes.
To fix this you have to select the actuall speed of your attached CPU to the board. Just set the actuall speed and save the changes. It will fix your problem.
Thanks
Iqbal
Posted on Mar 23, 2008
  • Iqbal Husain
    Iqbal Husain Mar 23, 2008
    Dear it varies from BIOS to BIOS so its not easy to loacte b.coz i dun have the same board. You should try in Chip Setup, or in Advance BIOS.
    Thanks
    Iqbal
  • Iqbal Husain
    Sharon try this....
    if you don't found the CPU speed setup, then Load defalut setup for each page in BIOS setup, it will fix the speed automatically.
    Thanks
    iqbal
My computer dont display any thing . But when i remove smps supply cmos bettery and ram. Then put in each place to run the computer. And gives cmos checksum error. What i do as that.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps
Apr 29, 2012 | Intel Computers & Internet
CMOS Checksum Erro
hope this helps you
Mar 15, 2012 | Gigabyte GA-8I865GME-775 Motherboard
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
Every time I reboot my pc I get the checksum error, all my defaults are loaded and also cant get to the setup
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 14, 2011 | Computers & Internet
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Computer not working with Samsung LCD TV
Your PC isn't working, the "CMOS Checksum Error" is a BIOS error. It has nothing to do with the monitor.
You have to let the PC load the default settings and try to boot up, if the defaults doesn't work, you have to reconfigure the options in the SETUP program. To enter Setup press "Del" or "F2" in the POST screen.
May 05, 2008 | Televison & Video
Cmos error
ok, a checksum error can refer to a flat cr2032 cmos battery, especially if the time is wrong at every boot.
May 26, 2007 | Intel SuperMicro SUPER Motherboard - 810...
EliteGroup P6STP-FL Motherboard Logo
278 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
