Question about Sharp AR-5316 Advanced Digital Imager Copier
Black line from paper - Sharp AR-5316 Advanced Digital Imager Copier
  • 3 Answers
If the black line appears when using document feeder only try cleaning the narrow strip of glass that is next to the main glass. If you get lines regardless of whether you're using the document feeder you may need a new drum (or you can try cleaning the drum).
Posted on Apr 24, 2010
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
A black line on the scaned page
If light going around the paper, and if upper white paper don't cover it, this part will be black. Try to cover with some part of white paper around. If you have black line in the middle of scan, you have hardware problem with scanner (or old buggy driver). Try to update scanner driver.
Aug 24, 2011 | Office Equipment & Supplies
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
Wide black lines down the paper. I have changed
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Nov 18, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Jan 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Black lines on photo
Are the lines always in the same places? If they are, then I would try using different photo paper. Humidity plays a big factor when printing with any kind of paper and buying new paper would be a good start. Make sure that the paper is made for your printer specifically. You might also try printing on plain paper to see if you get the same results.
Jan 17, 2008 | HP PhotoSmart 7760 InkJet Printer
Quality of printing
For the black line check the toner cartridge roller (usually covered by a movable flap) to see if there is a black line on it. If not, then check the transfer belt (looks similar to a conveyor belt) for a line (probably not black in color, possibly white or grayish). If either of these parts have a line your best option is to replace that part. You could try cleaning VERY gently with a dry lint-free cloth but this may only clear up a little of the issue.
As for the fold, try running a paper path test, usually found under test, information, or diagnostic menu option on the printer itself. Try to find anything in the paper path that may catch the paper and cause it to fold.
Hope this helps!
Nov 27, 2007 | HP Color LaserJet 2600n Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
