Question about Microsoft Windows Vista Home Premium Edition for PC
Vista insists on formatting any memory card I use
Recently, when I put any memory stick, or any device that uses flash memory like an ereader, PSP etc, into my Vista laptop, I get the "This device needs to be formatted before you can use it" message.
They all work fine in other machines.
Help!
Thanks,
Tim
    Guru:
  • 458 Answers
You must be having a problem with Windows Vista.
Some of the system files have been corrupted making it have operational problems.
To solve this problem, you will have to reinstall Vista or perform a system repair, using a Vista installation CD.
Thank you for using Fixya,
Kenneth
Posted on Apr 27, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
You must check your device manger in your computer and look there device microsoft iSCSi initiator if your not found in your device manager in your computer system you must update this device microsoft iSCSi initiator includ to your system computer. good luck
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Well I got a new psp with a 2 gb memory stick produo with a Memory Stick Duo Adaptor. Well this is the problem: When I insert the adaptor with the memory stick inside my computer won't show any files it...
Put the card back in the computer and format it using FAT (not NTFS) format. In the format menu, you'll see the file system pull down option, choose FAT and try and format it again.
Thanks Mark
Jun 24, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
I formatted a 16GB sony produo mem stick on my laptop using Win XP II. Now my computer or camera or PSP can't detect the card
Put the card back in the computer and format it using FAT (not NTFS) format. In the format menu, you'll see the file system pull down option, choose FAT and format again.
Feb 20, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Any idea hw to restore psp games
Backup up your games on a PC. Then Format your memory stick and put the psp games back in the memory stick if this does not work try formatting your psp by entering the recovery mode HOLD R + HOLD POWER...
Go to advanced/advanced config/format flash 1 and reset settings
if this also fails try using another memory stick on your psp
Feb 18, 2010 | Sony PlayStation Portable (PSP) Console
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
May 30, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Formate memory stick
try formating the card using a digital device such as a camera or a playstation portable (PSP)
May 17, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick problem
ur memory is skrew you need to get a new one i got the same problem.
May 17, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
My son's psp is showing memory stick on the screen and won't work
Its doin that cos some problem in the memory stick format it using card reader and then try(alwys ackup imp files before formatting)
Jan 20, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Microsoft Windows Vista Home Premium Edition for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
