Question about HP DeskJet D2560 InkJet Printer
I have just refill my original HP 300 Cartridge with a compatible black ink but i cannot get any print.It's like my printer cannot recognise the ink.An assistant told me to press the cancel button for 5 sec but nothing happened. What can i do?
  • 4 more comments
  • pantazidous Apr 24, 2010
    I'm sorry but i did what you said but nothing changed. Any other solution?
    when i used the original ink it used to print normally. When i used a refill ink it just print 3 pages and stoped. The printer takes the paper but it brings it out blank.
    but mhy friend what do you mean by printing normally? Actually, I cannot print anything. Pleas help me because I feel that this kind of chip pefills is a joke.
    I cannot give you any information for the ink because I do not have them.I bought the ink in a plastic container from a refilling store. An other information it may helps you understand my problem is that on my printer the light for the ink quantity is blinking.
  • 787 Answers
So your printer prints normally, only that there is no black ink on the paper?
Posted on Apr 24, 2010
  • Tudor Valean
    Tudor Valean Apr 24, 2010
    Try a print head cleaning. If this doesn't solve your problem, then the ink may be the cause. In that case, please tell me the manufacturer and the model that are written on the packaging box of the ink.
  • Tudor Valean
    I assume you already tried unpluggin, then plugging back the printer. In this case, you need to use original ink since the consistency of this "compatible" ink is different from the original ink.
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the printer from power source then press the power button for 10secs. while unplugged. Then plug the printer to power source again then press the power button. This should reset the printers system. Hope this helps and have a good one!
  • dj_relly999
    dj_relly999 Apr 24, 2010
    In addition, It may not work on first try so do the procedure over and over again. Good luck!
  • dj_relly999
    Good luck on this... have a nice day!
Ive just filled my ink cartridges but have the following error message when trying to print: (see add details section)
You need to reset the chip in the cartridge that tells the printer when it's low. The part can be found on sites that sell refill kits.
Aug 07, 2015 | Canon PIXMA MG3150 Inkjet Multifunction...
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Oct 21, 2009 | HP Photosmart C4180 All-In-One InkJet...
My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Jun 15, 2009 | HP Photosmart C7280 Laser Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Unable to print with new ink carts
Usually, that message means that your cartridge is dead. Try removing it, clean the electric contacts on it and the ones on the cartridge carrier. Put it back in. If that doesn't help, you will need to buy a new color cartridge.
If you do not have a replacement cartridge, you can still print in, what HP calls "ink backup mode". Simply remove the problem cartridge, and print with the remaining one, in this case, the black one.
  • If you remove the tri-color cartridge, printouts will be in grayscale.
Dec 23, 2008 | HP Deskjet D4160 InkJet Photo Printer
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP DeskJet D2560 InkJet Printer Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
