Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
My grill is not working. What could be the
I have a Leisure Rangemater 110 and my grill is not working, although connected to the gas supply and the other burners and oven are working fine. What could be the problem?
    President:
  • 1,015 Answers
The first thing you will need to do is try lighting the burner manually with a match or bbq lighter. Bring the flame next to the burner then turn on the griddle knob. It should light up. If it does then it is either a weak spark on the ignition system due to debris on the electrode or there is blockage in the burner eyes at the electrode. Try poking out the eyes of the burner with a safety pin or sewing needle. And try using a wire brush to lightly clean the electrode head(where the spark comes from). If your tried lighting the burner with a match or bbq lighter and it did not light or a very small flame came out then there is a restriction in either the burner eyes, venturri, or burner orfice. Frist inspect the burner eyes for any blockage(grease or particles of food) and then use the sewing needle or safety pin to clean out all the burner eyes. If the burner is easily removed then go ahead and remove it and check the venturri(burner pipe) for any debris inside it. A small bottle brush can be used to clear the venturri. And finally with the burner removed you should be able to see the burner orfice. It will look like a small nut(usually brass) with a very small hole in it. This is where the gas comes out and if this hole becomes plugged then the burner will not work. The best way to clear this hole is to use a very small wire like the wire on a sandwich bag tie strap. Burn the plastic off of the tie strap to expose the thin metal wire and then use the wire to clear out the hole. DO NOT USE ANYTHING LARGE to try and clear out this hole. It is tiny for a reason and the soft brass can be opened up easily while try to clear the orfice hole causing a huge increase in gas pressure. If you clear the orfice hole and still do not get any gas pressure then the next step would be to remove the orfice(this requires a orfice wrench) and verify that you get gas coming from the burner tube with the orfice removed. If you do not get any gas after removing the orfice the more than likely the problem lies with the burner valve restricted internally and will need to be re-built or replaced.
Posted on Apr 24, 2010
Leisure rangemaster 110
The switch may be faulty, turn off the power then remove the knob ,it just pulls off and shine a torch in to see if it looks burnt, also smell it often if the switch burns they have a distinct acrid smell.
May 07, 2014 | Kitchen Ranges
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Have leisure rangemaster 110 5487 ng cream. Have totally lost display for clock, timer etc. How do I replace this?
Phone Gas On Spares with model number 5487 followed by the following 6 numbers after 5487 and they will quote you for a replacement Programmer
Apr 11, 2011 | Rangemaster 110 (Gas) Kitchen Range
Can you help me find a user guide for leisure
I could copy my handbook of the Users Guide for a Rangemaster 110 Gas appliance if you wish and send it on to you, if that would help.
Oct 10, 2009 | Kitchen Ranges
Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Feb 26, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Feb 19, 2009 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
688 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
paulcarew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
