Question about Philips Magnavox 9P6034C 60" Rear Projection Television
TV want come on
Phillips Magnavox model 9p6040 C104 want come on should i replace the power board?
  • johnson9242 Apr 24, 2010
    Thanks for the help, hope you can help just a little more...I've already consulted several local TV technicians at a cost that I could have kept to repair this TV myself, Therefore I'm the Tech asking another Tech for help! Please tell me where I can get the Electical technical drawing for this make and model TV or buy the Power board at ? Philips does'nt sell the power board any more, I can replace the transformer my self, But I need some technical drawing of the location of parts. also there is some power going though this TV because the Led light comes on the front panel.
  • johnson9242 Apr 25, 2010
    This was great help but Iwant to get some more help from the same person.
    President:
  • 1,768 Answers
You have a power supply issue and or a possible be a bad cord.
There also may be a defective transformer at the primary side of the board which in any case repair at the board level. A tech will be able to determine this with test where the issue is on the main board.
I hope this helps.
Posted on Apr 24, 2010
I have a 60in phillips magnovox rear projection tv model number 9P6040 C104. The green power light comes on but I have no video/audio. And it makes a chirping type sound. Could someone please gice me some...
Your problem seems to be convergence. This has to do with the video/ audio. If your Tv has no video/ audio and make a chirping sound when you turn on the TV, the problem is within the convergence chips. The symtoms you describes gets to the heart of your tv issue. However your tv can be fixed and it does not have to cost you an arm and one of your legs. If you think you can tackle this repair by doing it yourself then I suggest giving it a go. You can order the kit (audio/video)repair kit/chirping. The cost is reasonable, $68.00. It comes with all the replacement parts and thorugh instructions to guide you through the process. Give it some thought if you think you can fix the tv, if not have a professional do the job. Good Luck.
Sep 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is going out
it is either ic 7411,7412, 7413 they are cheap replace all three, they are located on the back of the large signal panel right in the middle, very common issue. If you can't solder the repair may cost around 200 or so .
Sep 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have aMagnavox 9P6040 C104.The picture is extremely poor.
The problem is the fluid in the Blue and Green CRT's needs replaced. ( ethylene glycol ) It not something you should attempt if you've never done one. The average price with most shops is around $250.00, and your other concern, there is no auto convergence on that model. It's all done by remote in your menu and in the service mode, but that's not your issue, just get the fluid replaced and your back in business. Have a nice Holiday Weekend.
May 23, 2009 | Philips Televison & Video
Magnavox 9p6040
Sounds like a solder or connection issue on the small signal panel. which is the ciruit baord on the left hand side of the set looking in from the rear of the set.
Jun 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philps 60P8341A
I have a 60 in. Philip Magnavox tv that it haveing sound problems.It,s sounds when is in dvd ,but not when is in tv the model no.is 9p6040 c104. Does anyone have any ideas to fix this problem? Thank you........Lucy
May 03, 2008 | Philips Magnavox 27MS343S 27" TV
Color on projection tv 9P6040-C104
The cooling fluid in the CRT's need to be replaced. This is a common issue with NAP projection TV's. The old fluid needs to be drained then the CRT faces cleaned then refill with new fluid.
Jan 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
