Question about Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum
Dyson dc07 cant open trapdoor ?????
  • David Cleary May 11, 2010
    Did you take apart the cyclone to clean it?
  • 65 Answers
Might be clogged with dirt, take the canister to the trash bin, pull the trigger and try pulling it open from the bottom at the same time, there is also a way to remove the top of the canister where the handle is from the bottom clear canister part by the back side, there is a little lever.
Posted on Oct 02, 2009
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
How do I open the case on this hoover
If you cant figure out how to open it I wouldn't recommend you trying to rewire it, take it to a repair shop or ask your local friendly electrician.
Oct 19, 2014 | Vacuums
Does not pick up at all there is no suction
Check that the hose is not blocked. Also check the dust channel air ways (see the orange trapdoor on the underside and push your fingers through to see if there are any debris blocking the suction.). Also check that the filter on board is clean - if it is completely dirty it needs replacing as well as the dust bag.
Nov 21, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
My phone cant read pdf files, why is that?
You will need to install a PDF file reader in order to read PDF files, Adode is the most commenly used PDF file reader and the most commonly found provider of software, the chances are that if your phone cant read PDF files and you cannot install a PDF file reader, you may need to consult your phone manual, otherwise your phone may just simply not have that ability. I hope this helps.
Sep 03, 2010 | Vacuums
Red light on. Works for 2 minuets and then cuts out.  Does not ned a new bag.  Could it be the filter?
It could be a clogged bit of dust. Check the main hose, remove it by unlocking at the top and check the whole assembly including the pull out wand part. Then check the underside. Either inspect using the trapdoor or remove the beater bar and see if there is any clogged dirt behind that. Sometimes dust can get clogged around the neck of the floor head. If you unlock the body of the X from the floor head (button release is just below the main bin) check the main dust channel before it meets the wand. Sometimes it can be clogged with dust there.
Usually if the filters are black they can be cleaned with the exception of the foam motor filter on top of the hood. Cost replacements are usually easy to find online or on EBay.
Jun 25, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
I cant open my scooba
If you haven't used the scooba before or if it has been a long time, the pump may need to be primed.  Go to irobot and do a search for how to do this.  I also had difficulty opening my scooba.  Press down with the palm of your hand on the back silver plate as you push down on the silver release handle.  This worked for me.
Apr 28, 2009 | iRobot 5800 Scooba Vacuum
I have a Sebo X4 vacuum cleaner which has lost suction and is displaying the red bag clogged light. There is no apparent blockage in the pipework from brush to bag Any clues as to reasons/solutions?
There could be a few reasons:
Check that the main filters are completely clean - open the door to see if there is any dirt on the main slide out roll filter and also the main exhaust filter on top of the hood of the X4 (by pushing the handle all the way down to the floor as if the X4 is flat floor cleaning) The exhaust filter has to be replaced if its completely black in colour and can't be washed.
Failing that, check the main inspection blockage door on the underside of the floor head. Inspect it with a torch - even though it may feel like there is nothing there by putting your fingers into the trapdoor, debris like stiff cardboard can often block the main dust channel entrance from the brush to the main hose. Also take off the hose and extend it fully to see if anything is clogged.
Mar 31, 2009 | Vacuums
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
My windsor s12 vacuum light says the bag is full but it is new?
It sounds like a blockage in the hose or in the yolk.I believe you can remove the hose from the machine to inspect and clear it.Also check the trapdoor on the bottom of the powerhead to be sure it is clear.While you are going through the machine check under the upright filter next to the bag to see if it is clear.Good Luck-Scott
Oct 10, 2008 | Vacuums
Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum Logo
192 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
