Question about Linksys Wireless-G Broadband Router
How to install a wireless broadband router to a desk top computer?
  • 550 Answers
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on Apr 24, 2010
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless-g broadband router
1. On your computer, open IE and type 192.168.1.1.
2. By default there is no username and the password is admin.
3. Once you're in, set Internet connection type to what your ISP requires to have. If you have cable ISP usually it is just set to Automatic configuration-DHCP. If you have DSL ISP, it usually uses PPPoE.
4. But verify it with your ISP.
5. Whatever changes you do on that page, do not forget to click "Save Settings" which can be found at the bottom of the page.
Nov 06, 2008 | Linksys Wireless-G Broadband Router
Can not connect another desk top to wireless router
the link below will show you how to work on the wireless settings of your router and how to connect multiple wireless computers in a single network.
Setting up your Linksys router to have wireless security.
hope this helps, if you have other questions just let me know.
Nov 03, 2008 | Linksys WRT160N Wireless Router
I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Oct 06, 2008 | Computers & Internet
Routers
You can get a regular wireless G broadband router (WRT54G) But you must also check if your sprint modem has an ethernet port so that you will be able to connect the router to it.
Jun 29, 2008 | Linksys Wireless-G Broadband Router
Problem with initial install
hello!
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on
Step 7: test the Internet connection on both pc
if this still didnot work, upgrade the firmware of your router
May 30, 2008 | NetGear WGR614 Wireless Router
Setting up wireless router
If you plan on only using the wireless router once it's set up, you may as well get rid of the wired one right now. You can easily set up the wireless router while the wired is still running (plug your computer directly into the wireless router), but you don't need it. If you have a lot of settings you need to move over (port forwarding, QoS rules, etc.), open those configuration pages of your wired router in new browser windows so when you turn it off, you can see all your settings and copy them to your wireless router.
Mar 07, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
191 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
