Question about Dell Dimension B110 PC Desktop
Bought internal harddrive and don't know where 7-pin SATA port is on motherboard, or Sata power connector is from PC.
  • 251 Answers
Hi, sorry to tell you this but that model of dell desktop does not have sata ports or sata power connectors and has no spare drive bays to mount the hard drive either , you would be best to try and return the drive and purchase an external hard drive and connect it to your PC via the usb socket .
Hope this helps
Posted on Apr 24, 2010
Connections to the hard drive
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Dec 10, 2012 | Acer Aspire X1 AX1470-UR11P Desktop PC...
Need wiring diagram for placement of the internal cables in Compaq Presario SR5410F
Top view photo of the motherboard, of an MSI MS-7525 motherboard made FOR HP by MSI, for a Compaq Presario SR5410F Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01386897&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3686678
Also scroll down the page, and click on the + sign to the left of -
Motherboard Layout.
A) 24-pin ATX main power cable:
In the photo, look to the right of the Blue ram memory slots.
The Yellowish/Whitish connector to the right of them, with two columns of 12 socket holes, is where the 24-pin ATX main power cable plugs in.
In the Motherboard Layout it is marked by - ATX1
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the middle photo, and the Lock on the side of the power cable's connector. The Lock has a hooked end that goes over a Tab, on the motherboard's connector.
The Lock works like a see-saw on a playground. The top is squeezed in, and this brings the hooked end away from the Tab, in order to remove the power cable.
When assured that the power cable is plugged in tightly, and therefore correctly, the hooked end of the Lock will be over the motherboard connector's Tab.
B) 4-pin ATX +12 Volt power cable:
In the center of the motherboard, under the Processor socket, is the Northbridge chip. (Part of the motherboard chipset)
It is under a finned aluminum Heatsink, that resembles a meat tenderizer's head.
Draw an imaginary line up above it, in-between the Processor socket, and the aluminum finned Heatsink, and go straight LEFT.
See the whitish 4-socket hole square connector?
In the Motherboard Layout it is marked by - JPW1
This is where the 4-pin ATX +12 Volt power cable plugs in. It is power for the Processor. Has the same locking setup as the 24-pin ATX main power cable, and it's motherboard connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) In the Motherboard Layout to the top left corner of ram memory Slot 1, (DIMM1), is where the Processor fan connects.
CPU_FAN1
D) In the Motherboard Layout just below JPW1 is where the computer case fan plugs into. SYS_FAN1
E) In the Motherboard Layout - SATA1 - is where the SATA Harddrive data cable plugs into. (Below ram memory slots)
The SATA power cable from the power supply, plugs into the SATA harddrive. Note that the SATA power cable's connector, is longer in length than the SATA data cable's connector.
[SATA power cable has 15-pin. SATA data cable has 7-pins ]
Note that both cable's connectors, have an L-shape on the inside.
NOTE*
This is what a 4-pin standard Peripheral power cable looks like,
IF, your SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable!
Otherwise you will burn up the SATA harddrive. May not happen right away, but I assure you it will happen!
[ A note on SATA.
The beauty of SATA, is that you can plug into ANY SATA connector on the motherboard, and BIOS will see it.
If you plug the Harddrive into SATA 1, or SATA 2, or SATA 3, or SATA 4, connector on the motherboard, IT DOES NOT MATTER.
BIOS will find the Harddrive, or optical drive ]
The Front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the Motherboard Layout illustration, the Front Panel header is down at the Bottom/Right corner, and is marked - JFP1.
(Right in the very bottom/right corner is JUSB2. JFP1 is right above it)
JFP1. Junction Front Panel 1.
9-pin header. Black rectangle.
5 pins on the Right side, 4 pins on the Left side.
The pins are numbered EVEN on the LEFT side.
Starting on the BOTTOM going UP;
Pins 2, 4, 6, and 8. There is NO Pin 10.
The pins are numbered ODD on the RIGHT side.
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
(Light Emitting Diode, so it is a light )
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt power, and reserved for the factory to use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Aug 14, 2012 | HP COMPAQ Presario SR5410F Pentium...
Wiring diagram emachine T5246
OKAY!
There's what I'm talkin' about!
The model number.
The eMachines T5246 Desktop PC uses a
Foxconn/Winfast MCP61PM2MA motherboard.
[You stated Foxconn/Winfast. I got that. Just letting you know ]
Guess what?
So does the Gateway GT5476E Desktop PC,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
Click on - Product Views - in the list.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
If you need a pinout for the Front Panel header, click on -
S - Front Panel connector
The Top row is numbered EVEN. Starting from the Left side going to the Right;
Pins 2, 4, 6, and 8. There is NO pin 10.
[Colors going from Left to Right;
Orange/Yellow, Orange, Green, Green ]
The Bottom row is numbered ODD.
Red/Yellow, Red, Blue, Blue, Yellow ]
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
B) Pins 5 and 7 are a Reset switch, IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. This was used by the factory. It is N/C.
Not Connected.
Any other connector info you need? Post in a Comment.
Specifications,
http://support.gateway.com/s/PC/R/1009603/1009603sp2.shtml
1) Ram Memory:
Uses DDR2 Sdram at 667Megahertz. (667MHz)
Maximum TOTAL amount for the motherboard is 2GB. (2 GigaByte)
Maximum Amount for each Ram Memory slot is 1GB.
IF, you just have one ram memory module, make SURE it goes in ram memory slot 1. (DIMM 1)
That is the ram memory slot closest to the Processor.
Uses a SATA harddrive, and IDE (PATA) optical drive/s.
Does have two SATA connectors on the motherboard, so it can use ONE SATA optical drive.
On those SATA connectors on the motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rmvr12.shtml
See the bottom SATA connector has SATA 1 next to it?
The SATA harddrive is supposed to be plugged into it.
However, the beauty of SATA is, NO MATTER WHAT SATA connector you plug into, BIOS will find that device.
Want to plug the SATA harddrive into SATA 1? No problem.
Want to plug the SATA optical drive(CD/DVD drive) into SATA 1?
No problem.
Want to plug the SATA harddrive into SATA 2? No problem.
Want to plug the SATA optical drive into SATA 2? No problem.
BIOS will find the device.
For additional questions please post in a Comment.\
Regards,
joecoolvette
Aug 02, 2012 | E-Machines Computers & Internet
NO POWER COMING ON
The Acer Aspire E500 Desktop PC uses an Acer MBP2207024 motherboard,
http://www.ascendtech.us/acer-aspire-e500-mbp2207024-motherboard_i_mbacembp2207024.aspx
I'll be referring back to the photos of the motherboard, at the bottom of the page of the above link.
Start with the power cables coming from the Power Supply, to the motherboard.
1) 24-pin ATX main power cable, and corresponding connector on motherboard:
Middle and bottom photo. Look at the top left side. There is a whitish long connector, with 24 socket holes in it, on the motherboard.
Here is an average example of the power cable, and the connector on the motherboard,
[Note* Color of connectors does Not matter ]
2) 4-pin ATX +12 Volt power cable:
It's hard to see in the photos. Go to the bottom photo.
From the left side; look at the purple Keyboard port, and green Mouse port.
Go to the right to the blue VGA port. (15 socket holes. 3 rows of 5)
Now go to the stack of 3 ports to the right of the blue VGA port.
Two USB, then a Firewire port on top. Right behind this stack, is the square 4-socket hole, whitish 4-pin ATX +12 Volt connector.
Average example of motherboard connector, and corresponding power cable,
Note that on the male power cable connector, for the 24-pin power cable, and the 4-pin power cable, there is a Lock.
Shown more visibly in the middle photo of the above link.
This Lock acts like a see-saw on a playground. The top is squeezed in, and this action releases the hook at the bottom end, away from the tab on the female motherboard connector.
To ensure that these power cables are plugged in tight, the Lock needs to be in the lock position, over the tab on the female motherboard connector.
This power cable is power for the Processor.
That's it for the motherboard.
There should also be a SATA power cable coming from the Power Supply, to the SATA harddrive.
Average example of a SATA power cable,
Note*
There are two cables going to a SATA harddrive. The SATA power cable has the longer connector. It has 15 pins. Note that there is also an L shape on the inside of the connector. Lines up with the L shape on the harddrive.
The other cable is a Data cable. (information cable)
It has 7 pins, and is the shorter of the two.
Average example of a SATA data cable, and corresponding connectors on a motherboard,
Look at the photos to the top/right. The top photo shows an average SATA data cable. (Color does Not matter)
The photo also shows a Straight connector. This style of connector is usually used to plug into the motherboard. (Sometimes for SATA optical drives, also)
An Elbow shaped connector is usually used on the Harddrive side.
[ NOTE*
This is a 4-pin standard Peripheral power cable,
Shown connected to an older IDE (PATA) harddrive. It is also used on optical drives, and to computer case fans sometimes.
Point:
IF, your SATA harddrive has a provision on the back for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Otherwise the SATA harddrive will BURN up.
May not happen immediately, but I assure you it will happen.
In the middle and bottom photos on the Ascendtech link, the SATA headers (Connectors) on the motherboard, are Orange, and at the Top/Right.
There are 4 of them.
The beauty of SATA:
Next to the SATA headers on the motherboard will be silkscreened a figure. SATA0, SATA1, SATA2, and SATA3.
Or it may have SATA1, SATA2, SATA3, and SATA4.
A harddrive should plug into SATA0, or SATA1.
HOWEVER, the beauty of SATA, is that you can plug the harddrive into ANY of the four SATA connectors on the motherboard, and BIOS will find it.
The plastic front of your computer is the Front Panel.
The rectangular block of plastic with pins sticking up out of it, on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Sometimes abbreviated as F_PANEL, or FP1, or PANEL_1.
Looking at the Top motherboard photo, it is the blue rectangular connector, at the Bottom corner.
In the Bottom motherboard photo, it is all the way to the Bottom/Right corner.
(Middle photo all the way to the right corner)
The CPU Fan, (Central Processing Unit, or also known as Microprocessor, or Processor for short), cable connects to the small 3-pin whitish connector, that is towards the top of the motherboard, and above the 24-pin ATX main power cable connector.
The System Fan, (SYS_FAN), or computer case fan, connects to the small 3-pin connector to the Right, of the 4-pin ATX +12 Volt connector, on the motherboard.
Front Panel header pinout to follow in a Comment.
Regards,
joecoolvette
Jan 21, 2012 | Acer Aspire E500 PC Desktop
Cannot find the sata plug on motherboard
A SATA harddrive uses a SATA power cable,
(15-pins, long connector. Harddrive side connector is usually a 90 degree elbow,
Cables are usually Red with Black connectors, but cable, and connectors can be ANY color )
,and a SATA Data cable,
A SATA Data cable has the shorter connector. It has 7-pins.
{ SATA power cable provides power to the SATA harddrive.
The SATA Data cable is the information cable. Data,..information, is transferred back, and forth across this cable }
This is a 4-pin standard Peripheral power cable. The connector on the end of the cable is referred to as a 'Molex' connector.
(It is a misnomer. Molex was the first design name, from the first company who made it. The name stuck. Kind of like calling an open-end adjustable wrench, a Crescent wrench ),
IF, the SATA harddrive has a provision for plugging in a 4-pin standard Peripheral power cable, AND a SATA power cable,
ONLY USE JUST THE SATA POWER CABLE
Otherwise you will burn up the SATA harddrive. (Maybe not right away, but I assure you it eventually will happen)
The connectors on the end of the SATA power cable, and SATA Data cable, have an L shape on the inside.
This L shape needs to be matched up with the L shape on the harddrive for the SATA power cable, and harddrive AND motherboard, for the SATA Data cable.
The beauty of SATA technology;
IF, there is more than one SATA connector (Header) on the motherboard, the harddrive can be plugged into ANY one of them.
For example if there are 4 SATA headers on the motherboard;
They can be labeled SATA 1, SATA 2, SATA 3, and SATA 4,
OR,
SATA 0, SATA 1, SATA 2, and SATA 3.
The harddrive usually plugs into SATA 0, or SATA 1.
With the SATA technology however, you can plug into ANY of them, and BIOS will find the device. (In this case a harddrive)
For the HP Compaq Business Desktop D330 computer, the motherboard is an Asus A8SN-CF (HP/Compaq name = Phoenix),
http://h10010.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00858789&product=321856#N31
All I see is one SATA header (Connector) on the motherboard. It is at the top right area, and is Black in color.
(Right below the thin green label on the edge of the motherboard, at the top. Third connector from the right)
Go down, and click on the + sign to the left of -
Motherboard Layout.
Look at the Top, and third connector over from the Right side.
You can barely make out - SATA1.
Motherboard installed in the computer case, the SATA 1 header (Connector) is at the Bottom of the motherboard.
Third connector (Black) over from the left side.
(Remember, there is NO such thing as a silly question)
Regards,
joecoolvette
Jan 16, 2012 | HP Compaq Business Desktop d330
I have a 81845gvm-rz gigabyte motherboard with internal HDD of 40GB capacity, now i am looking upgrade my internal HDD some where near 500gb is it possbile doing it. i need more free space on my c:\ drive...
The new harddrive technology you refer to is SATA.
A SATA power cable is used,
,and a SATA Data cable is used,
To the upper right of the page shows a SATA Data cable connector, on the end of a SATA Data cable.
Below it is an example of a SATA header on the motherboard. Color does Not matter.
The SATA power cable connector has 15 pins. The SATA Data cable connector has 7 pins. Both connectors use an L shape on the inside, to line up the connection.
The type of older Harddrive technology you are using now is IDE.
It is also known as PATA.
Uses a 40-pin flat ribbon cable for the Data cable. (Note* Only 39 pins are used. One hole is blocked off, or has no wire )
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
The Gigabyte GA-81845GVM-RZ motherboard's Storage Controller Type support is IDE, [ DMA/ATA-100 (Ultra) X 2 ],
http://www.dealtime.com/Gigabyte-Gigabyte-Technology-i845GVup-to-2GB-DDRDIMM-3DDR/info?tab=specs
There are no SATA headers on the motherboard,
http://www.ebay.com/itm/Gigabyte-GA-8I845GVM-RZ-Motherboard-DHL-UPS-3-8-DAY-/390337518730?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D180645618978%26ps%3D63%26clkid%3D5166955561701266148
HOWEVER,....all is not lost. You can install a SATA Adapter Card in an unused PCI (White long slot), and use a SATA harddrive.
Example of a SATA Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329305&CatId=1455
With the above SATA Adapter Card model, you will have 4 internal SATA headers. They are on the adapter card.
[ Also advise maxing out the Ram Memory, and using the best Intel Pentium 4, Socket 478 processor, that you can obtain.
The CPU Support Chart is available on the Gigabyte Support main page]
Regards,
joecoolvette
Dec 26, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Proper installation of tower wires
According to Gateway Support, the Gateway 505GR desktop computer uses an Intel (Ausberg) 915G motherboard,
http://support.gateway.com/s/PC/R/3724/3724iv.shtml
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWAUGSBURG
Scroll down to the photo with the sections marked in red.
In the top link, looking at the motherboard with the computer case open, the USB and Firewire (1394a) cables, can be seen attached to the motherboard near the letters D, E, and F.
In F that red cable is a SATA cable. One end attaches to the back of the SATA harddrive, (The angled end), and the other end of the SATA cable attaches to one of those SATA headers on the motherboard.
(SATA header = SATA connector on motherboard)
Preferred SATA header for the Harddrive is SATA 1.
DOESN'T matter though. That's the beauty of SATA. You can plug the SATA data cable into ANY SATA header on the motherboard, and BIOS will find the harddrive.
In the second link, looking at the motherboard photo shown, and comparing it to the view of the motherboard as mounted in the computer case, the Front Panel header is at the very Bottom Right.
Two rows of pins in a White rectangular shaped header,
(S points to Front Panel header)
[ The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel wires go to, is the Front Panel header ]
A) Top row has Even numbered pins
B) Bottom row has Odd numbered pins.
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
1) Power LED = Power On LED light
2) Hard Drive Activity LED = LED light that flashes (Usually red in color) when your harddrive is active. Being used.
3) Reset switch = Reset Button. The Reset switch is behind the Reset button. (IF the computer uses a Reset switch)
4) Power Switch = Power On switch
5) Forget about Pin 9. That's for 5 Volts DC - Out. Used by factory.
Which wires coming out of the Front Panel, are the Power On wires, Harddrive LED light wires, Power On switch wires, etc.?
Remove the Front Panel, and trace where the wires end.
IF, the wires already installed coming from the motherboard to the Front Panel, are Too short, you should make notes before you remove them from the motherboard.
Note what color pair of twisted wires, went to where, in the Front Panel.
Compare to the chart of the Front Panel header given above.
(IF any wires are still connected to the Front Panel header on the motherboard)
Once the Front Panel is removed, it's usually pretty easy to trace the two wires up to the Power On switch.
Same for the Power On LED light.
Again, same for the HarDDrive activity LED light.
The SATA harddrive requires a DATA cable, and a SATA power cable.
The connector for a Data cable has 7 contact pins. It is the shorter connector.
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The connector can be at a 90 degree angle as shown, or a straight connector.
IF the data cable has an angled connector, it plugs into the Harddrive.
Straight connector goes to the motherboard.
The connector for a SATA power cable has 15 contact pins. It is the longer connector,
Note the L shape of the connectors for the SATA data cable, and SATA power cable.
Also;
This is a 4-pin standard Peripheral power cable. Commonly misnomered as a 'Molex' power cable,
IF, the SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Using both power cables will burn up the harddrive.
May not happen immediately in some cases, but WILL eventually happen.
Regards,
joecoolvette
Nov 17, 2011 | Gateway 505GR PC Desktop
I replaced my power supply and don't remember where the connections went
Not too much way you can go wrong. There's a 20 or 24-pin connector which plugs into the motherboard in only one place. There probably is a 4-pin connector and that, too, goes into the motherboard (in a socket near the CPU). The other connectors are power connectors for you hard drive and CD/DVD. That's about it.
Oct 09, 2011 | HEWLETT-PACKARD Compaq Presario SR5518F...
Recently changed the power supply. There is no video output. Where can I download the motherboard schematic?
Right here at HP Support,
1) Motherboard Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00361570&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459491
Scroll the page down to the top view illustration, and photo.
A) The motherboard uses a 24-pin ATX main power cable.
In the illustration the connector on the motherboard is on the right side.
It is an empty rectangular box with ATX Power Connector in it.
On the motherboard photo it is the rectangular white connector with two rows of 10 socket holes, and is to the bottom right of ram memory slot 2.
Another example of a 24-pin ATX main power cable,
Ensure that the 24-pin ATX main power cable's connector, is locked into place on the motherboard's connector. The lock tab on the main power cable must be hooked over the tab on the motherboard connector. This ensures that the main power cable is in all the way.
B) The motherboard uses a 4-pin ATX +12 Volt power cable.
The connector on the motherboard is a white square connector, with 4 socket holes.
In the illustration it is to the bottom left corner of the Processor socket (LGA 775), and has ATX12V underneath it. This power cable's connector also has a lock tab.
Another example of a 4-pin ATX +12 Volt power cable,
Power TO the motherboard, that's it.
Power FROM the motherboard:
C) System Fan, and CPU (Processor) Fan.
Abbreviated as SYS_FAN, and CPU_FAN to the bottom left of the ATX12V connector.
(4-pin ATX +12 Volt connector on the motherboard)
The System Fan is the computer case fan.
CPU Fan is the Processor fan.
D) The four SATA headers on the bottom right in the photo, (Blue, Orange, Black, and White), are for the SATA data cables.
They connect to a SATA harddrive, or SATA optical drive. (CD/DVD drive)
(They are an L shaped connector inside, with 7 pins inside)
Power for these SATA devices comes from the Power Supply.
The Power Supply has SATA power cables.
Example of an average SATA power cable,
(L shaped connector with 15 pins inside. The longer connector between a SATA data cable, and a SATA power cable )
Did you forget which SATA data cable plugs into where, on the motherboard?
Don't sweat it.
The beauty of SATA is that you can plug the harddrive's SATA data cable into ANY of the SATA headers (Connectors) on the motherboard, and BIOS will find it.
Same with a SATA optical drive, or any SATA device, for that matter.
IF, your SATA harddrive has a place on the back for BOTH, a SATA power cable, and a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
Using both will eventually burn out the SATA harddrive!
Example of a 4-pin standard Peripheral power cable, (Misnomered as 'Molex'),
From there the main optical drive, (CD/DVD drive), has to have the audio cable plugged into the audio connector on the motherboard.
(Plus the power cable, and data cable, of course)
In the illustration this is the header down in the very far left corner, and located towards the bottom edge.
It has CD_IN marked underneath it.
In the photo it is the Black rectangular connector in the very far left corner.
If you didn't connect the 4-pin +12 Volt power cable, your Processor isn't getting any power.
No Processor operating, No computer.
No Signal on monitor.
(No video signal)
Regards,
joecoolvette
Jul 24, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
How to install a second hard drive
pmarrs177 you are quite welcome!
I suppose I better post this as a solution, instead of in a Clarification.
This way when someone looks for this type of information, it will be available in a search hit on the internet.
Your problem and my solution will be on the internet for years to come. (Also easier to read) Congratulations! You'll be known worldwide as one more person, who helped bring the mysteries of SATA to be a little bit less mysterious.
Installing it as a secondary storage Harddrive?
Did your Acer T180 model come with a SATA harddrive already installed?
There are several different models of the Acer T180.
Some examples: AST180-UA380A, AST180-U381A, AST180-UA380B
Some of these came with a PATA harddrive, and some came with a SATA harddrive. (PATA is also referred to as ATA, IDE, and EIDE)
Why the question? Because when Windows is first installed on a computer, you are asked if you wish the SATA drivers to be installed.
The model version of an ACER T180 that came with a SATA harddrive, has these drivers already installed.
If your Acer did come with a SATA harddrive, and you are installing an additional harddrive for more storage, just plug the SATA data cable into ANY available SATA header on the motherboard.
BIOS will find the harddrive. Just one of the nice features about SATA.
You can use ANY SATA header on the motherboard. {Not shouting}
(A connection on a motherboard is a Header. This is what a SATA header on a motherboard looks like, doesn't matter what color it is.
{Top right photo on page)
The SATA data cable, usually has a 90 degree elbow on one end. This end connects to the Harddrive. Doesn't always have a 90 degree elbow, but most of the time it does.
The straight end connects to the motherboard. There are 7 pins used in the connector.
The SATA power cable has 15 pins.
Scroll down the page in the above link, for photos of the end connector for a SATA data cable, and the end connector used for a SATA power cable.
NOTE*
IF, you do not have an unused SATA power cable coming out of your Power Supply, see if you have a 4-pin peripheral power cable that is not being used.
(The connector end is referred to as a 4-pin Molex connector. It is whitish in color)
This shows what a 4-pin peripheral power cable looks like,
Buy an adapter power cable that connects to the 4-pin Molex connector, and has a 15-pin SATA power cable connector on the other end.
Example: http://www.directron.com/idesatapower.html
Mar 13, 2010 | Acer Aspire™ T180 PC Desktop
Dell Dimension B110 PC Desktop Logo
85 people viewed this question
Alun Cox
