Question about Intel Server Board SE7505VB2 Motherboard
I added NEW rams to my intel SE7505VB2 Motherboard and when i start the Server i hear beeps in the form of 4-3-1-3 with Blank Screen when i googled the beep codes for Phoenix BIOS i got: Initialize the Chipset!!! What does that mean? And when i put back the original RAMs it works fine
    Genius:
  • 1,354 Answers
It means you are traing with diffrent RAM module
this is your Sever Moduals
Memory Memory Type DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 8 GB
or go to link u will find all the details of your server
http://www.dealtime.com/xPF-Intel-Server-Board-SE7505VB2
Hope this helps you in your troubles!
If it does, be sure to give me a thumbs up.
Posted on Apr 24, 2010
Can i put dual core processors in my intel se7505vb2 motherboard?
http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm
Page 16 of the Technical Product Specification guide;
3.1.1 Processor Support
"The Intel Server Board SE7505VB2 supports one or two processors in the 604-pin FCPGA package."
-> Socket 604,
http://en.wikipedia.org/wiki/Socket_604
-> Intel XEON processors ONLY
"When two processors are installed, all Processors MUST be of identical revision, core voltage, and bus/core speed."
-> Means you really should use two IDENTICAL processors.
"When only one Processor is installed, it should be in the socket labeled CPU1, and the other socket must be empty."
-> Self-explanatory.
That's the processor socket furthest away from the black AGP graphics expansion slot, and closest to the outside edge of the motherboard.
(Page 104, and 105)
ONLY supports Intel Xeon processors with a 400MHz, or 533MHz FSB.
Dual-Core Xeon's start at 667MHz, and wouldn't work anyway; due to different Core architecture, and Instruction Sets.
667MHz, 800MHz, 1066MHz, and 1333MHz, for dual core Xeon's,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#Xeon_.28UP.2FDP.29.2C_Dual_Core_2
(Scroll down just a touch, to get the Wikipedia 'banner' out of the way, or click on it's X)
Scroll down the page, look at the charts. Starts with 800MHz FSB for Dual Core, then goes 667MHz, 800MHz, 1066MHz, and 1333MHz, Front Side Bus.
Use Dual Core processors?
No.
Two Single-Core processors.
Product Guide for the Intel Server Board SE7505VB2,
(Motherboard manual),
http://download.intel.com/support/motherboards/server/se7505vb2/prod_guide.pdf
The above is a direct link to the PDF file, motherboard manual.
If it doesn't work just by clicking on it, then copy it; and paste it in your browser address bar. Press the Enter key.
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, or press the Enter key; it may take up to 30 seconds before the first page comes up.
Didn't want you to wait a few seconds, and think nothing is happening)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2012 | Computers & Internet
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Jun 25, 2012 | Computers & Internet
Blank screen and beeping when pc starts
i think you should check your RAM. when you hear beeping and blank screen that means your RAM is faulty.
Aug 05, 2010 | Gigabyte Matx Intel G31 775 DDR2-800...
After powering up the server it gives three long beeps and no vga is displayed,removed the memory and inserted new memory.
remove the new ram and start the pc if the beeps still then it must be the new ram incompatable with the bus speed
Dec 01, 2009 | Intel Server Board SE7501WV2 Motherboard
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Blank screen long beep 2 short beeps at startup.
The 1 long 2 short beep code means a problem in the video circuitry and the laptop can't initialize the display. This is usually caused by failure of the integrated video chipset. Unfortunately, on a laptop you can't just open the case and install a new video card like you can on a desktop. You need to replace the mainboard. Replacements are available online. Here is one source found by a Google search. (I'm just using this as an example. I haven't dealt with this site.)
The 4 beep code means no memory detected when the computer started up. No surprise there since you had taken it out.
Apr 23, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Intel Server S5000VSA gives 3 beeps and no BIOS display.
According to the following document (pages 14-19) published by Intel .. That memory module is not listed as tested/working with that board.
Feb 19, 2009 | Intel S5000VSA Motherboard
Not turning on
I find if you don't hear a beep...then the RAM could be faulty or wrong values.
Some Ram uses 2 RAM slots to boot.Hope this helps.
Dec 31, 2008 | Intel Motherboard
Beep code in server mbd.
no RAM is getting detected.
change the RAm and try
Jun 16, 2008 | Intel Server Board SE7505VB2 Motherboard
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Intel Server Board SE7505VB2 Motherboard Logo
173 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
