Question about Sony Grand WEGA KDP-65XBR2 65" Rear Projection Television
Sony KDP-65XBR2 won't turn on. Standby light blinks 6 times.
I have a Sony KDP-65XBR2 that won't turn on. It gives 6 blinks of the standby light. After looking around inside, I've found the Flyback Transformer is cracked and bloated. After some research, I've found that the Flyback is involved in high voltage generation. If I replace that, should the TV go back to functioning? Is it likely that other components have been damaged?
Thanks,
Ray
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
Slinteriors
  • 8617 Answers
SOURCE: Having Trouble With Flyback
Yes you will need to unsolder the old flyback and solder in the new however its very basic soldering required. Yes the d board will have to be removed just remove the screws and then press the plastic tabs in that secure the board to the plastic frame. Then the HV lead has to be rotated 90 degress and then removed they come out quite roughly. Its best to grab onto theHV lead with insulsted pliers and then rotate and pull with a twisting motion to get it to release.
Posted on May 19, 2008
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Posted on Nov 24, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Posted on Apr 15, 2009
Where can I buy OEM CRT (red,gree, and blue) for KDP-65XBR2?
I think none are available any more--you may find a company who will rebuild the tube but that is expensive.
Jun 05, 2012 | Sony Grand WEGA KDP-65XBR2 65" Rear...
TV will not turn back on and the standby light is blinking
if u pay attention the tv will after goes into shut down would go into dignoses mode , it would blink 6 - 7 times , stop and repeat againg 6-7 times this is high voltage power supply , the repair on this unit is very complicated but if u open this tv , look close tho the flyback transformer and next to it there is a small chip the part # start with (mz ) little black chip like i said is close to the flyback , it have like 8 leg on each side
Nov 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
The standby light keeps blinking and tv won't turn on
when it blinks 6 times,you have to replace an ic.
its named mcz3001d and is located near the flyback transformer.when you heat it up ,the tv will work.
so you can check if that is the problem
Apr 07, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
My KV-34HS420 won't come on and the Standby light
The system has found issues with your TV.. The only solution is to call in service. Tell them the 6 blinks.. it is a code for diagnostics. Sorry.. the logic portion of the TV is experiencing some kind of breakdown. The only suggestion that I can offer is to hard reset your TV to factory settings.. other than that you are in duck soup..
Sorry...
Stan Skaggs
Oct 19, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony 11 blinks
Blink code only goes to 8 on this model. Are you sure its not 5 and 6? That would be AKB and Horizontal stop, respectively. Quite likely a flyback transformer on this model.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Red standby light light blinking
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Dec 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Tv wont turn on ???
sounds like a power regulator problem, a horizontal drive problem,or the horizontal output is shorted because of a bad flyback transformer. If your not a technician there are no user serviceable parts inside these sets and i would advise you to take the set to a pro and have it diagnosed as you could get seriously killed fooling around inside of a tv set. God Luck
May 14, 2006 | Sony KV-VF14M40 14 in. TV/VCR Combo
Open Questions:
Sony Grand WEGA KDP-65XBR2 65" Rear Projection Television Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
