Lamp Light On
I was watching TV and all of a sudden the tv picture went off and the lamp led on fron come on. It will notcome on properly now
Magnavox DLP 50"
  • 8,617 Answers
You will need to replace the lamp.
Posted on Mar 23, 2008
SOURCE:
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
Tv went of when we watching it i did disconnect it and a red light came on where the power button is does tv have a lamp
Tv "LAMP" LED light indication flashes or light up?Yes,the tv projection lamp life is over.Replaced the tv projection lamp.
Sep 27, 2010 | Samsung HC-P4752W 47" Rear Projection...
Tv lamp light stays on.
The projection lamp inside on this tv,about 1 1/2 or 2 years,tv on and watches about 4 or 5 hours a day?The projection lamp life are over.Tv require a new projection lamp.
Jul 05, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
I have a Samsung 56" DLP tv. was watching and it went off. light on lower front blinks 3 times, when attempt to turn on. Could it be the lamp light?
Does these LED indicator lights that blinks?It is one of the LED light said lamp or bulb?The tv been used alots,and it at lest 2 years.U have not change the tv lamp or bulb to this tv?Change it,life of the lamp it over.
May 03, 2010 | Samsung HLP5067W Television
I was watching tv when the screen suddenly went blank. I tried to power off and back on. The power button blinks a red light and nothing happens
The TV has sound, but no picture.
The lamp is the most common part that causes this symptom. If you have purchased a new lamp already, click on the “Signs of Lamp Failure” link below to check your lamp or contact who you purchased your lamp from for a warranty claim. Look at the indicator lights on the front of the TV and use our chart by clicking the link below to find out what error the TV is displaying to help you. If you have not purchased a new lamp, the lamp is the most common and cheapest repair for this symptom. A defective circuit board can also cause this symptom in which you should contact a certified/trained TV technician.
If your lamp shows any of the signs listed below, there is a high probability your lamp is defective.
Find DLP lamps by model number
Common Signs Of Lamp Failure
- Cloud or haze near the center of the lens.
- The burner (the stem in the center of the lamp) is broken
- The burner has a white bump on it (usually near the bottom)
If the lamp does not have any of the characteristics described above, you check by brand below for LED flashing light codes to keep troubleshooting.
Sep 10, 2009 | Panasonic Televison & Video
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
TV Magnavox 50ML8105D/17 Problem
I have the same problem my DLP TV would shut off after 30 minutes or less all red LED's. Solution: The fan on the lamp assembly was not turning at the proper RPM (bearing going bad) so it was going into overtemp mode. The original part number was a SUNON KDE1209ptv3 12v 1.3W I had a hard time finding one to match that spec. DIGI-KeyCorp (www.digikey.com) was able to cross reference it to a 3 lead P11034-ND part number (NMB-MAT model fba09a12L).
I Installed the fan and problem went away.
Procedure:
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
Feb 21, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
