Question about Sunpentown HA3011 Portable Air Conditioner
Blinking ''comp'' light and unit unresponsive
"comp" light blinking. Unit unresponsive to buttons on panels
  • jeffwhitehea Apr 25, 2010
    The blinking "Comp" light issue with this unit and several other similar Sunpentown Portable AC units is - the water tray is full and requires draining. The drain plug is found at the bottom on the backside of the unit.
    These units have a water tray that is used to blow cool air to increase the unit's efficiency by decreasing the need for compressor cycles. This tray can get full and needs to be drained occasionally esp. in humid conditions.
    Thank you for responding to my query.
  • 34 Answers
Without knowing that brand of unit as i don't think they are sold in Australia, I think that the system will have lost its' gas charge. If you remove the small nut cap where the gas pipes enter the outside unit and depress the Schroeder valve, and you have little or no pressure released, then you have a leak on the system.
Posted on Apr 24, 2010
Testimonial: "I will check the unit as you suggest and report back. Thank you."
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Outside A/c unit stays on for 1 min then off.
check comp capacitor if its ok check the overload protector if its ok then the compressor have to be changed
Feb 24, 2009 | Heating & Cooling
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blinking indicate at indoor unit
reset your unit by disconnecting the power supply for 10sec. and "on " the unit for testing. if error persist you need to replace your thermistor.
Jan 25, 2009 | Carrier 38CKC042 Air Conditioner
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
Sunpentown HA3011 Portable Air Conditioner Logo
332 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
