Question about Kenmore Dishwashers
I have a sears dishwasher, lock light is lit but
I have a used sears dishwasher in house I bought, the lock light is lit but it won't unlock keypad to run cycles. Help! kids are tired of watching me do dishes by hand!
    President:
  • 949 Answers
Press and hold the 'Heated Dry' button for 4 seconds then let go
Posted on Apr 25, 2010
Kenmore Elite 665.1392 / 665.1394 Control Lock Light is on. No other buttons are responsive. Dishwasher won't run.
The control lock should toggle on and off if you press and hold that button (on the right side of the group of buttons) for 3+ seconds. Until the lock is released, the other buttons won't work. If the lock won't release, either the keypad or the control board are not communicating the unlock signal between them. (This could indicate a problem with the wiring, one or both of the two boards.) The parts list for the 665.1392 control panel is available here: http://www.searspartsdirect.com/model-part/66513922k010/0583/0130000/k1203262/00002.html . There may be other sources for the parts.
You'll need to open up the control panel to do any diagnostics. If your dishwasher is still under warranty, contact Sears for a service call.
I hope this helps.
Apr 26, 2016 | Kenmore Dishwashers
Green light is flashing and it didn't finish cycle and won;t restart
had same problem,,sears replaced the touch keypad and the related circut board
Aug 03, 2009 | Kenmore Dishwashers
Bought a house with a craftsman garage keypad, but no code.
yes. hit learn button on logic board on motor and enter 4 digit code and hit enter. light bulb should flash. that is it.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
How do you unlock the keypad?
We had this problem with ours, It is the 'control lock' that is on, a child safety 'feature' that can be turned off by holding the air dry or pro dry button for four seconds.
Dec 20, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Control Lock light remains on
Vince, press and hold the keypad next to the lock symbol. (heated dry?) see if the lock light goes out. Catriver..post back
Mar 19, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
119 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
