Question about Oster 4100-50 Juicer
The "reamer" is stuck on my Oster Citrus juicer model 4100-20. Can anyone tell me how to take it off?
I need a reamer for my oster 3181 citrus juicer
I need a reamer too for my oster juicer........can't locate anyone in India who supplies........ Let me know if you are aware
May 31, 2011 | Oster 3181 Citrus Juicer
Could you please tell me if i have to remove the peel before using the juicer
What does the manual say? Depending on the item your putting in is whether or not you have to peel it or not. Typically no, you don't peel the fruit before using a hand juicer, but it it's a matter of taste.
I don't peel mine.. I aim to get all the vitamins and minerals that i can obtain from fresh fruits and veggies.
Some oils in the peel are making the juice bitter though, you have to do a trial and error on that. On Lemons because the white pith on the lemon (just under the yellow bit) can be quite bitter, and it will inadvertantly end up in your drink.
It will not cause you any problems if you do not peel the lemon. It's just a matter of taste. I just looked through all my juicer manuals and "Juiceman" says to leave them all on except for oranges and grapefruit due to their "extreme bitterness". My Waring manual (the one I use now) says you can do it either way but recommends you buy their citrus reamer. The other manuals say to peel them.
If this advice was helpful a vote for the thumbs up would be greatly appreciated
Mar 24, 2011 | Juicers
How do I use the Automatic Citrus Juicer Model CE22651?
Hi Abiola, How you dey? Anyway regarding your questions, you should check the manual guide that came with it, or if the juicer is not a new one and you don't have the manual.. You can download any of this manual guide from the link below:
http://www.devicemanuals.com/userguidesearcher.php?search=juicer&query=title&x=27&y=11
I've looked everywhere for the exact Continental Automatic Citrus Juicer Model CE22651, but all with no avail. I would suggest you read other juicers manual, as long as you get familiar with those ones you will be able to operate any kitchen juicer -- Any Model!!!
Once again, visit the link above to download any Juicer manual guide that suits you.
I hope that works for you.
Mar 10, 2011 | Continental CE22651 Juicer
I am juicing oranges with ths acme juicerator and all I get is thick sluge instead of licquid juice. Can you help me I have a lot of oranges to juice.
Not really designed for juicing oranges. There is a citrus attachment but it costs too much,
better off buying a $20 citrus juicer.
Feb 19, 2011 | Acme 5001 Supreme Juicerator Juice...
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
Feb 08, 2011 | Omega 1000 Juice Extractor
Is any repair possible for the citrus attachment? the juicer cap will not spin when pressure applied down on the fruit.
I have the citrus attachment, but never use it because
it spits the stuff all over the place. Better off going
with a $15 or $20 dollar citrus juicer. Sounds like
the inside gearing may have broken and new one is
like $50.
Jan 04, 2011 | Acme 5001 Supreme Juicerator Juice...
For an Oster Juicer Model 3165, how do I remove the stainless steel basket? Thanks.
Move from side to side and jiggle the whole assembly .. including the juice collector and juicing basket. With patience and even a break between attempts it will finally dislodge itself and lift up and off.
Just juiced carrots and a couple apples .. mmmm good ;-) best of luck
Aug 23, 2009 | Oster 3186 Citrus Juicer
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
Help it is my juicer
your juicer...nice idea...and what might you need for the juicing experience?
Mar 23, 2008 | Juicers
Juicers Logo
41 people viewed this question
Top Oster Juicers Experts
Tom Chichester
David Payne
David Payne
Are you an Oster Juicer Expert? Answer questions, earn points and help others
