Question about RIM BlackBerry Curve 8310 Smartphone
Need help to reset the software on my blackberry
I want to download a software for fixing the ''app error'' problem on blackberry 8520
Ok there are some things you need to do.
1 you need the disc that came with your 8520 This disc help you load desk top software. 2 You will need to backup your phone. You can still use this older software.It was make for the older blackberry. Now is your phone for personal or business. If you can backup all your important information on a 8-16 gb micro scan memory card. The more gbs on the memory card the more room you will have.If you need help ican walk you through the process on your computer. The curve is an older blackberry. It can be a memory problem. I suggest you get a bigger memory card and put it into your phone.
Apr 17, 2014 | RIM BlackBerry Curve 8520 Smartphone
Blackberry password last attempt
you need to download the blackberry desktop manager to a computer you can get it here http://us.blackberry.com/software/desktop.html , after that you need to plug in your blackberry and the program should recognize it, after that go ahead and hit the update option.
Oct 19, 2013 | Cell Phones
Is there software to factory reset a blackberry
Yes, according to BlackBerry's Knowledge Base it's possible to reset your phone back to the factory defaults - but first you need to backup your files.
You can read an article here ("How to reset the BlackBerry smartphone...")
...and this one may be interesting as well: "Reset a BlackBerry smartphone"
Hope it helps.
Jun 19, 2012 | Vacuums
Acts like it wants to come on then goes to a black screen, red light flashs
Hi, Perform a hard reset on the BlackBerry smartphone.
To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
If the battery is working, download the latest BlackBerry Device Software and install it using the application loader tool in BlackBerry Desktop Manager.I hope this information will be helpful to you.
Nov 20, 2009 | RIM BlackBerry Pearl 8100
I have a JUM Error 545 incompatible or corrupt filesystem and it will not reset
The Blackberry Device Software is corrupted. You need to install the latest version of the BlackBerry Device Software on the BlackBerry smartphone.
To perform a clean installation of the BlackBerry Device Software using Blackberry Desktop Manager 4.5 to 5.0, perform the following steps:-
1) Open BlackBerry Desktop Manager.
2) Click Help.
3) Select About Desktop Manager.
4) Click the Device Software tab.
5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
I hope I was able to help you.
Thank you for using Fixya.
Oct 22, 2009 | RIM BlackBerry Pearl 8100
Need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Mar 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
My little brother reset my blackberry HELP ME PLZ I NEED MY PHONE
From Pinstack.com---> If you do get locked out, to reset your password would require a low level reset, or "nuke", which is a fairly drastic procedure. A low level reset wipes out your BlackBerry's memory completely, including the operating system. To make it functional again, you would have to cradle the device and reinstall all the BlackBerry software.
Mar 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
BLACKBERRY 8700 HOURGLASS HELP
If your hourglass of death is occuring after a hard reset - Battery pull. It suggests a software issue.
You will need to reload your software, using desktop manager.
Mar 07, 2009 | RIM BlackBerry 8700g Cellular Phone
Blackberry wont work
Red light only = unhappy blackberry user. The unit needs professional attention or replacement.
Jan 16, 2008 | RIM BlackBerry 7290
RIM BlackBerry Curve 8310 Smartphone Logo
121 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
